Help me identify this part, Found in the tin in front of fan |
DNHunt |
Dec 24 2004, 06:17 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
This little key is 5/8" X 3/16". I don't recall putting it in the new engine. Should I be worried?
Attached image(s) |
914werke |
Dec 24 2004, 06:27 PM
"I got blisters on me fingers" Group: Members Posts: 10,146 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Dave ...... (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
Isnt that the key for the fan Mount? |
dgw |
Dec 24 2004, 06:35 PM
Dennis Winter Group: Members Posts: 553 Joined: 7-January 03 From: Santa Cruz Mountains Member No.: 106 Region Association: Northern California |
Yeah, isn't that the key that locks the fan on the crank?
If that came out I would think you could move the fan pretty easily. |
DNHunt |
Dec 24 2004, 06:36 PM
Don't know but I hope not. It might be a little tough to do with the enging in.
Dave |
914werke |
Dec 24 2004, 06:45 PM
From Pet:
9, 901 102 147 00, WOODRUFF KEY, 1 |
914werke |
Dec 24 2004, 06:47 PM
How do You capture the image out of PET?
Tryin to send post it for you Dave |
boxstr |
Dec 24 2004, 06:59 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Dave I would be very very worried, I don't think I could sleep at night. But then that is just me.
CCLINTHEKEYTOYOURHEART |
skline |
Dec 24 2004, 07:16 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
It can be put back in with the engine installed, I have done it a lot. Just hope it didnt do any damage to the crankshaft. Dont run it without that in there.
Mark Henry |
Dec 24 2004, 07:37 PM
STOP!!!\
Yep!! it's the fan hub key! If you don't have one it will take out your crank! Be safe and make sure. |
Rocky |
Dec 24 2004, 07:43 PM
From the cockpit Group: Members Posts: 341 Joined: 24-March 04 From: Gig Harbor,WA Member No.: 1,845 |
Dave, I'm holdin one just as you described. What I can't understand is how it came out as you prolly installed the fan well ahead of the tin. It's like working blind but it can be installed in the car.
I took mine out today for shits and giggles on any and all curvy roads given the dry weather. You'll be glad you made the heat exchangers. Happy holidays to all, Tim. (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Rocky |
Dec 24 2004, 07:46 PM
Damn Mark, I got wood lookin at all thoes heads on your avitar.
Tim |
balthazar |
Dec 24 2004, 08:19 PM
P-car junkie Group: Members Posts: 161 Joined: 23-March 03 From: Arvada, Colorado Member No.: 464 |
Um...I guess I'll ask the obvious (and betray my ignorance!!) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) But, how does the fan hub key come flying out the front of the engine? Is it sloppy engine building? Does this happen to high mileage engines? How might I ensure that my current and future engines don't have this problem? Is this some sort of engineering/design flaw with the T4?
Happy Holidays Fellas! (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
Mueller |
Dec 25 2004, 12:57 AM
It cannot "fly" out...period...no way, no how !!!!
possibly just unlucky, when he installed the hub, it might have come loose, or it could still be installed correctly on the crank and this is an extra part from another project??? We won't know until he takes it apart, he needs to measure it 1st, if the dimensions are too far off, then i wouldn't worry about it, however if the dimensions match what belongs in the crank, then I'd be cussing (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
No
Don't worry about right now with your current engine and when you rebuild your engine remember to install it....
No, it is not, it might be a human error and that is all, the Type IV engine is a very robust engine |
TC/914 |
Dec 25 2004, 02:08 AM
Member Group: Members Posts: 203 Joined: 21-October 04 From: Southern MA Member No.: 2,981 |
It might also be the WOODRUFF KEY that's used on the inner half of the alt. pulley.
Joe Bob |
Dec 25 2004, 06:52 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
With the indents on the edges....looks like a beat up/severed dime....
Joe Ricard |
Dec 25 2004, 07:22 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Actually I would do it from underneath. Just take the front apron sheet metal off. You should be able to get at the fan hub while seeing what you are doing. Plus you get another chance to gawk at that beautifull motor from the under side one more time. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Good luck Any chance it came from the other crank when it was pulled apart? WAY LONG TIME AGO????
DNHunt |
Dec 25 2004, 09:40 AM
Well I took the front apron off and then the fan and hub and I found a Woodruff key right where it was supposed to be in the crank. Guess I'll try the alternator next.
Dave Attached image(s) |
davep |
Dec 25 2004, 10:36 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Unless the pulley came off of the alternator, there is no way for the key to get out. As you can see the key fits into a hole in the shaft. It cannot slide out. Then there is the washer and nut on the end it could not get past.
Rusty |
Dec 25 2004, 10:39 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
My guess is that it's an extra. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
I've been finding extra parts in my engine compartment for years. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) -Lawrence |
Eddie Williams |
Dec 25 2004, 10:41 AM
Senior Member Group: Members Posts: 822 Joined: 30-December 02 From: Nederland, TX Member No.: 55 Region Association: None |
never say never
Lo-Fi Version | Time is now: 12th June 2024 - 05:43 AM |
