3 Pages V  1 2 3 >
> MS guru's! What MS for a /6 turbo?, researching and deciding on a system, bit OT, it's for a 930
Mark Henry
post Nov 27 2013, 10:34 PM
that's what I do!
Researching a FI system for a buddies late model 930, not much more than a low mile stock 3.4 engine with cams and a bit beefier snail.
I have another bud with a totally gonzo 930 with SDS, that car is a rocket (450+hp, extreme heads, paulter rods...etc.) and the SDS runs flawless on it, so SDS is in the running......But this guy has a clewette/electomotive crankfire (missing tooth) dual plug coilpack system already, so MS is a definite candidate as well.
So what would be the best system that uses (ties into) the existing ignition?
I can solder or would a finished system (like MS3 pro) be better?
I know many of you have gone this route so I'm hoping to pick some brains. (IMG:style_emoticons/default/smile.gif)
McMark
post Nov 27 2013, 10:48 PM
914 Freak!
I got MSIII.
RonW
post Nov 27 2013, 11:04 PM
ms3 or microsquirt
McMark
post Nov 27 2013, 11:25 PM
914 Freak!
MicroSquirt won't handle ignition on a six if he ever wants to go there.
iamchappy
It all happens so fast!
Im old school running a 86 Ruf CIS euro 930 fuel head, twin plug, msd ignition, with extra fuel enrichment via a 7th injector run off an rpm module. Not rocket science but works surprisingly well.
Getting into an EFI system costs $ and takes time to dial in but is the ultimate solution, electromotive or any of the new ignition systems are good.
Mark Henry
post Nov 27 2013, 11:36 PM
that's what I do!
QUOTE(iamchappy @ Nov 28 2013, 12:25 AM) *
I believe that's close to what he's running now except he's using the electromotive cranktrigger and their GM style coilpacks.
Mark Henry
post Nov 27 2013, 11:39 PM
that's what I do!
QUOTE(McMark @ Nov 28 2013, 12:25 AM) *
Must run the existing electromotive set-up or some type of crankfire, definitely wants to be able to retard ignition, etc. under boost.
Mark Henry
post Nov 28 2013, 06:44 AM
that's what I do!
So what I'm reading is the build time on an ECU is about a day?
So before I start making up a list is this all I need for the MS3 ECU?
http://www.diyautotune.com/catalog/megasqu...case-p-419.html
It describing this as a "daughter board" so is there also a "mother board" I need to buy?
This confusion of too many options is one of the only things that's kept me away from MS
I see the expander board as well and I know there's a list of other bits needed, that's not what I'm talking about right now.
Just the complete ECU then I'll post a complete other parts list.
Thanks
rick 918-S
post Nov 28 2013, 08:25 AM
Hey nice rack! -Celette
QUOTE(Mark Henry @ Nov 28 2013, 06:44 AM) *
So before I start making up a list is this all I need for the ECU?
Thanks
Same deal for me. I've been to the MS web site a number of times and started to read all the stuff. By the time I was 5 minutes in I was staring at my computer like a deer in the headlights trying to figure out what I was supposed to build or buy.... (IMG:style_emoticons/default/wacko.gif)
Someone should do a post with like what they purchased, how much it cost and how much time it took to build it or is there s generic ready built one out there. I want to run ITB's that I am building manifolds for.
Mark Henry
post Nov 28 2013, 08:40 AM
that's what I do!
QUOTE(rick 918-S @ Nov 28 2013, 09:25 AM) *
I hear ya Rick, I'm not asking peeps to do my homework for me, just a quick low down on what MS parts are needed, tools needed, time involved (trigger and intake fab is already done), etc.
Just a ballpark on some of the stuff.
I've done several SDS installs so I'm not a total newbie and I do know my way around FI and custom fab.
I'm not getting paid for this, just hopefully some experience, tools and leftover bits as a tip.
If it's a lot of work maybe a MS2 board for me??? who knows.....
rick 918-S
post Nov 28 2013, 08:47 AM
QUOTE(Mark Henry @ Nov 28 2013, 08:40 AM) *
Sounds like you have a good understanding. My F.I. experience is Porsche C.I.S. and stock L-Jet and D-jet on BMW and 914's Nothing with MS or SDS.
So does MS have a pre-built unit? Which one? Is Micro Squirt a pre-built that you taylor to your sensors and injectors? What to buy...what to buy..... (IMG:style_emoticons/default/idea.gif)
Mark Henry
post Nov 28 2013, 09:02 AM
that's what I do!
QUOTE(rick 918-S @ Nov 28 2013, 09:47 AM) *
Yes, my buddy is looking at MS3pro which is a pre built, but it's mo'money.
Hopefully someone with experience will chime in, but if not i'll be happy to share any info I find out.
What engine is your system going to be for? /4, /6, the Alien?
rick 918-S
post Nov 28 2013, 09:18 AM
QUOTE(Mark Henry @ Nov 28 2013, 09:02 AM) *
I'm working on a set of intakes for a 4 that is different than what is currently being shown with the other system projects posted here. McMark was boasting about Micro Squirt. If that's a pre-built I would be interested in starting with that.
jimkelly
post Nov 28 2013, 10:05 AM
Delaware USA
I believe you can get is assembled as well
http://www.diyautotune.com/catalog/megasqu...2e0032edca49e62
mega vs micro
http://www.ms3efi.com/feature-xref.html
note: I could have sworn that I recently saw a mega unit that had a sticker on it, that said, for off road use only?
rick 918-S
post Nov 28 2013, 10:54 AM
QUOTE(jimkelly @ Nov 28 2013, 10:05 AM) *
mega vs micro
Ya, I was surfing the microsquirt site and there was a disclaimer about using it on emission vehicles.
jeff
post Nov 28 2013, 11:05 AM
This system is really nice, if money is no object I would go with a motec setup but this stuff works and is very user friendly...
http://sdsefi.com/
Mark Henry
post Nov 28 2013, 11:26 AM
that's what I do!
QUOTE(jeff @ Nov 28 2013, 12:05 PM) *
http://sdsefi.com/
SDS is in the running, if you read my first post you'll see I've installed several SDS systems including the system that was in my 914/4 that's now going on my bug.
In fact I was using SDS long before Jake was.
DBCooper
post Nov 28 2013, 11:37 AM
14's in the 13's with ATTITUDE
The SDS is "simple," which is good, but that's also another way of saying "limited." One of the bad things about Megasquirt is that it's not "limited", so there are an awful lot of things to deal with. Sometimes that's too much for hobbyists or people getting involved with modern fuel injection for the first time, but not an issue for people who already have a good background.
QUOTE(rick 918-S @ Nov 28 2013, 08:54 AM) *
In California and maybe other states vehicles need to pass both a functional (sniffer) test but also a visual, with nothing changed from the way the manufacturer delivered the car. Obviously the MS boxes won't pass that test, so that's the disclaimer. I think McMark was working on a way to put a microsquirt into an OEM ECU box if you want to keep the vintage look on a T4. He also does general Megasquirt so would be the guy to talk to.
Another option is Mario at the Dubshop, who was recommended by DIY Autotune to re-work a board my son fried. He's all aircooled, only does Megasquirt, he likes new ideas, and I know has background in turbo tuning. Plus can do simple English translations of the MS-speak babble. Website is http://www.thedubshop.net/shopping.html . Good guy and recommended.
Mark Henry
post Nov 28 2013, 11:45 AM
that's what I do!
QUOTE(DBCooper @ Nov 28 2013, 12:37 PM) *
The SDS is "simple," which is good, but that's also another way of saying "limited." One of the bad things about Megasquirt is that it's not "limited", so there are an awful lot of things to deal with, sometimes too much for hobbyists or people getting involved with modern fuel injection for the first time.
In California and maybe other states vehicles need to pass both a functional (sniffer) test but also a visual, with nothing changed from the way the manufacturer delivered the car. Obviously the MS boxes won't pass that test, so that's the disclaimer. I think McMark was working on a way to put a microsquirt into an OEM ECU box if you want to keep the vintage look. He also does general Megasquirt so would be the guy to talk to.
Another option is Mario at the Dubshop, who was recommended by DIY Autotune to re-work a board my son fried. He's all aircooled, only does Megasquirt, and he likes new ideas. Plus can do simple English translations of the MS-speak babble. Website is http://www.thedubshop.net/shopping.html . Good guy and recommended.
I don't find SDS limited, if the final product is the same price I'll take SDS any day.
My other buddy already has a 450hp 930 turbo running SDS with zero issues. He has more money into the engine than most here have into their /6., $10K just into the custom Xtreme heads alone.
I'm sure Mario does nice work.
rfuerst911sc
post Nov 28 2013, 12:28 PM
If anyone is interested I have an Autronics unit I bought from Jake Raby but I never installed. Jake had it installed I think on a Boxster for a dyno run when he was doing comparisons of different ECU's. Other than that never used. Has the wire harness, injector harness she's in excellent condition. I'll never use it I'd like to see it go to someone that could use it. PM me if interested.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 11:07 AM
