Oil Pressure Relief Valves, How Many? |
Allan |
Dec 30 2004, 04:22 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
My Haynes book shows 2 oil pressure relief piston & spring assemblies in the case. I have the one at the bottom right front side of the case but there is nothing at the top left front. Is this normal? Do some have both and others just the 1? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Or maybe I am just missing something?
Mark Henry |
Dec 30 2004, 05:08 PM
Bottom right front
and a small one left side rear |
Allan |
Dec 30 2004, 05:13 PM
I took another look and at the bottom left. Right in front of the taco plate I have what looks like an oil galley plug about the size of a quarter. Nothing that can be removed without machining.
Allan |
Dec 30 2004, 05:18 PM
I have looked in every nook and cranny on both cases and cannot find anything resembling a removable object. I'll post pics from all views of the case tomorrow and maybe someone can point out where it should be.
Mark Henry |
Dec 30 2004, 05:37 PM
Bottom right front (opposite side from taco plate, right on the bottom) it's about a 1" big slot screw.
The small one is right between the #1 cyl pushrod tubes and has a M12 (I think) 12 point hex. |
Allan |
Dec 30 2004, 05:48 PM
I found a hole between the #1 push rod tubes but it is about 1 1/2 inch deep and just ends. No threads, nothing. Looks like it was designed into the casting but never completed. Just a deep hole that goes nowhere.
Mark Henry |
Dec 30 2004, 07:33 PM
Ahhh...must be your '76 engine case...it doesn't have one ...don't worry about it.
Did you find the other one? it's the one that matters. |
Allan |
Dec 30 2004, 07:37 PM
Yep, got the other one. It's the big one. I was thinking that I ended up with a bus engine or something. Thanks for clearing that up. So this is normal? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Mark Henry |
Dec 30 2004, 09:05 PM
Yeppers on some of the late cases...a bus case is easy to spot...it has a big fuch'in hole above the taco plate.
A 914 case has the boss for this hole but it isn't machined. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:09 AM |
