Getting gas tank boiled/cleaned/painted, East Bay Area? |
boxsterfan |
Dec 27 2013, 12:03 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
So, one of my projects this winter is to get all of my fuel system redone. This includes replacing all rubber fuel lines (already have SS lines in the tunnel and through the engine bay), replacing fuel filter, etc...
1. Where can I take my tank in San Ramon to have it cleaned/boiled, sealed (if needed) and repainted? 2. Is there any way to put the fuel filter in an easier place to change? |
Mike Bellis |
Dec 27 2013, 12:47 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I'm not sure of a place that does all those things to a tank around here. I would call Panky's Radiator in Hayward for the boil. If they can't do it, they will know who can.
Once boiled, you could do a POR15 seal and paint yourself. My fuel pump and filter are in the front trunk... |
boxsterfan |
Dec 27 2013, 01:03 PM
Thanks Mike. Oh, and anyone know where I can get a new rubber gasket for inside my gas cap?
Mike Bellis |
Dec 27 2013, 01:07 PM
gothspeed |
Dec 27 2013, 01:41 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
This tank sealer seems to have a lot of great reviews .... (IMG:style_emoticons/default/smile.gif)
http://www.kbs-coatings.com/tank-sealer.ht...ack-to-top-link |
McMark |
Dec 27 2013, 05:43 PM
This is the only sealer I use. Caswell Epoxy
I prep tanks with Marine Clean (to dissolve petroleum/oil) and Metal Ready (to erode rust deposits) from POR-15. Then dry thoroughly with a heat gun before applying the epoxy. Most other tank sealers are 'gummy' and for a plastic type sheet. If this sheet starts to separate it will simply pull away from the walls and could completely clog the fuel system. The epoxy is a hard coating. Should a section start to separate, which is already unlikely, the epoxy would crack or chip off. These fragments will sit in the bottom of the tank and shouldn't affect the fueling system. When I use this system, I dump the extra on my shop floor to seal that as well, little by little. I have one patch that has sat for 4 years of driving over, jacks being drug over it, etc and it's still fine. |
Rotary'14 |
Dec 27 2013, 06:00 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:28 PM |
