Oil Pressure Sending Unit, Mounting with hose? |
boxsterfan |
Jan 3 2014, 05:30 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
One of my other projects this winter is to get an oil pressure gauge installed. I want to use the dual-sender unit (can purchase from PP or wherever).
I have read before that some people take out the original sender and install a hose and then attach the dual-sender to that hose. Of course, wiring from there to your gauge and idiot light. For those that have done this: 1. What kind of hose? And size of hose ends? 2. Where did you mount the sender and how? Pic helpful.... TIA... |
Cap'n Krusty |
Jan 3 2014, 05:39 PM
One of my other projects this winter is to get an oil pressure gauge installed. I want to use the dual-sender unit (can purchase from PP or wherever). I have read before that some people take out the original sender and install a hose and then attach the dual-sender to that hose. Of course, wiring from there to your gauge and idiot light. For those that have done this: 1. What kind of hose? And size of hose ends? 2. Where did you mount the sender and how? Pic helpful.... TIA... Stand back, a shitstorm is likely about to happen. Personally, I use a readily available grease gun hose with a 1/8"NPT male fitting on at least one end. Some say a paintball hose works. You have to wire a ground for the sending unit housing. I mount them on the fan shroud, using a plastic covered ring clamp, like the ones used to route hoses and wires in a hot rod. I've done this on a lot of cars over the years and it works well. Be sure the sender you use matches the characteristics of the gauge, and the cutoff pressure for the lamp. The Cap'n |
boxsterfan |
Jan 3 2014, 05:45 PM
Thanks Capn'. I'm going to assume that one end of the hose has to be male and the other female.
How long of a hose do i need to mount the send unit up on the fan shroud? I wonder if i could get it mounted off one of the bolts for the coil mounting bracket? |
malcolm2 |
Jan 3 2014, 06:06 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Let me be the 1st to suggest the also readily available and cheap and available in various lengths..... THE PAINT BALL GUN HOSE. Shit storm or not, it is perfect. Been to long since I knew all the thread sizes, but it works. Someone will speak up, if not get with me and I'll pull out my files.
I ran the hose up to the fan and made a small "L" bracket, used one of the fan screws to attach it. even use the OEM oil pressure wire on my VDO sending unit. (IMG:style_emoticons/default/post-2-1117899824.gif) Follow the metal braided hose. |
stugray |
Jan 3 2014, 06:15 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The 1/8" NPT greasegun extensions will work just fine.
About $5 at your FLAPS |
michael7810 |
Jan 3 2014, 06:24 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I used the grease gun hose and a bracket from Ace Hardware used to hang pipe (I think it was for 1-1/2" pipe). The bracket fit perfect to an existing threaded hole on the fan housing. The only mod was adding a self-locking nut to the bracket clamp.
boxsterfan |
Jan 3 2014, 07:56 PM
Awesome!! Thanks for the pics!!
stugray |
Jan 3 2014, 09:57 PM
Cap'n Krusty |
Jan 3 2014, 10:04 PM
I'd just like to say I think those installations are REALLY nice! I especially like that clamp .....................
The Cap'n |
wndsnd |
Jan 3 2014, 10:16 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
The only thing I would add is the grease gun and paint ball hoses will need a coupling at the sender unit and that is another potential leak point.
There is a kit that comes with the coupling attached but it is like $30.00 John |
stugray |
Jan 4 2014, 12:02 AM
QUOTE I especially like that clamp ... Thanks! Here's the opposite side: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1367906573.2.jpg) The idea was to unthread the gauge and thread in the stock idiot light once I am happy with the VDO giving me accurate pressures. I dont want to race with that weight hanging off of the bracket. |
euro911 |
Jan 4 2014, 05:11 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Wow, nice looking motor, Malcolm (IMG:style_emoticons/default/smile.gif)
So, what is the thread size for the sender unit? "Be sure the sender you use matches the characteristics of the gauge, and the cutoff pressure for the lamp." What is the 'lamp cutoff' pressure? Also, what is the part # of the sender unit for this application? |
Lo-Fi Version | Time is now: 11th June 2024 - 12:25 AM |
