> Cleaning carbon, off pistons
Elliot Cannon
post Jan 6 2014, 05:28 PM
Group: Retired Members
After getting my heads rebuilt I am Finally getting around to putting my engine back together. Can anyone recommend a good (easy) way to clean the carbon deposits off the heads? Can this be done OK without removing the cylinders?
SLITS
post Jan 6 2014, 05:57 PM
"This Utah shit is HARSH!"
Put it back together ... fire it up and pour a cup of water slowly down the intake(s) at 2000 RPM .....
or
in your case
Fine wine!
jimkelly
post Jan 6 2014, 06:29 PM
Delaware USA
is oven cleaner NOT safe ?
r_towle
post Jan 6 2014, 06:34 PM
Custom Member
QUOTE(SLITS @ Jan 6 2014, 06:57 PM) *
or
in your case
Fine wine!
Except the wine suggestion.
Oven clean is not safe inside a motor....no no no
you can use it outside, but I would not do it.
A wire wheel also works.
post Jan 6 2014, 07:24 PM
(IMG:style_emoticons/default/agree.gif) w/ Schlitz. squirting it in with a bottle doesn't kill the engine as easily. Glad to see you back. I was beginning to think those "old charges" were brought up against you. (IMG:style_emoticons/default/stirthepot.gif)
Elliot Cannon
post Jan 6 2014, 08:20 PM
QUOTE(76-914 @ Jan 6 2014, 05:24 PM) *
Three arrests, NO convictions. (IMG:style_emoticons/default/flag.gif)
Elliot Cannon
post Jan 6 2014, 08:23 PM
QUOTE(SLITS @ Jan 6 2014, 03:57 PM) *
or
in your case
Fine wine!
Your $hitin' me right? (IMG:style_emoticons/default/dry.gif) Water down the intake? How about a small brass wire wheel? Will that work OK? I don't want to damage the top of the piston. Is that even possible?
yeahmag
post Jan 6 2014, 08:32 PM
Water does work, but a squirt bottle works better. Just keep from stalling it.
r_towle
post Jan 6 2014, 08:37 PM
Custom Member
High pressure steam cleaning.
Google it, it has worked since before slits was born.
euro911
post Jan 6 2014, 08:43 PM
We use to de-carbonize using water while on a dyno (on running engines)
Pull the jugs off one at a time, stuff rags on the case opening and wheel them. You don't want to nick the tops of the cylinders.
SLITS
post Jan 6 2014, 08:55 PM
QUOTE(euro911 @ Jan 6 2014, 06:43 PM) *
No wire wheel marks on the top of the piston either.
Water works
or
Brake cleaner & rags
r_towle
post Jan 6 2014, 09:00 PM
Custom Member
My concern with any type of wire wheel is all my wire wheels get smaller with time and use, and eventually there are no wire pieces left.....so they go somewhere, and you might get one lodged into the side of the piston, just laying on top of a ring, and you won't see it.
Then you know what it might do...
Use water or rags and cleaner.
StratPlayer
post Jan 6 2014, 09:06 PM
StratPlayer
http://www.orisonmarketing.com/pistonkleen.html
jeffdon
post Jan 6 2014, 09:37 PM
QUOTE(Elliot Cannon @ Jan 6 2014, 06:23 PM) *
or
in your case
Fine wine!
Hey Elliot....How many miles on that motor? I had about 8k on mine, and had some nasty carbon, but my plugs have always read a nice mixture. How much carbon and how fast the build up is natural?
SLITS
post Jan 6 2014, 09:47 PM
Ok Av8tor .... The water hitting the hot cylinder flashes to steam instantly, creating a shock which cracks the carbon deposits. They chip off and go down the exhaust.
As I remember your pic, the deposits are shiny, like being wet. Looks like oil. Try the Brake cleaner first and see if the deposit dissolves somewhat easily.
McMark
post Jan 7 2014, 01:34 AM
914 Freak!
Why bother? Or are you planning on tearing down the engine to clean the pistons before each Concours event? (IMG:style_emoticons/default/av-943.gif)
Seriously, everything you clean will be back on there in short order. Don't waste your time.
Elliot Cannon
post Jan 7 2014, 02:12 AM
QUOTE(McMark @ Jan 6 2014, 11:34 PM) *
OK! Now this is an answer I can live with. (IMG:style_emoticons/default/biggrin.gif)
ConeDodger
post Jan 7 2014, 06:58 AM
Apex killer!
QUOTE(Elliot Cannon @ Jan 7 2014, 12:12 AM) *
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif)
Mark Henry
post Jan 7 2014, 09:29 AM
that's what I do!
As a builder I've never liked the water trick... (IMG:style_emoticons/default/dry.gif)
Wait a second...bent rods = more work (IMG:style_emoticons/default/idea.gif)
Nevermind....carry on.... (IMG:style_emoticons/default/smash.gif)
Matt Romanowski
post Jan 7 2014, 09:38 AM
McMark is right. If you're not taking it all the way apart, leave it alone. You're only going to get more crap in the motor and oil. That is not an excessive amount of carbon and will be back after about 10 minutes of running.
- Lo-Fi Version Time is now: 2nd April 2026 - 09:20 AM
