WTB: 73 1.7 engine compartment pieces, Will update as I find other pieces that I need |
David_S |
Jan 9 2014, 10:21 PM
Member Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region |
Trying to get my 73 1.7 back together finally and I need a few pieces that are either broken or lost. I will try to update this as I buy or find more stuff missing or broken !! I need .....
Engine controller mount .... Mine is half there and my 76 is rusted beyond use. Stud/wingnut that holds the air cleaner assembly to the engine bracket. My air cleaner rubber boot has been cracked and it looks like the PO siliconed the crack up. Mine seems to be usable, but I would prefer to use one that isnt cracked if a decent one is out there. Let me know what you got that you want to get rid of !!!! David |
euro911 |
Jan 9 2014, 11:12 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Trying to get my 73 1.7 back together finally and I need a few pieces that are either broken or lost. I will try to update this as I buy or find more stuff missing or broken !! I need ..... Bruce Stone (bdstone914) probably has all of itEngine controller mount .... Mine is half there and my 76 is rusted beyond use. Stud/wingnut that holds the air cleaner assembly to the engine bracket. My air cleaner rubber boot has been cracked and it looks like the PO siliconed the crack up. Mine seems to be usable, but I would prefer to use one that isnt cracked if a decent one is out there. Let me know what you got that you want to get rid of !!!! David |
bdstone914 |
Jan 10 2014, 10:36 AM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The ecu bracket is a two part design .
I have them. Should have a 1.7 intake boot. Maybe on the wing nut. Bruce |
David_S |
Jan 10 2014, 03:00 PM
Bruce, let me know what you have if you dont mind. I am needing both pieces for the ecu bracket I think. I will double check tonight to be sure.
bdstone914 |
Jan 10 2014, 04:11 PM
David,
Does your ECU have an adjustment knob on the top? There are two different brackets depending on if it has the idle adjustment knob. I have both. Here is a picture of the intake boot. Bruce Attached thumbnail(s) |
David_S |
Jan 11 2014, 07:32 PM
Bruce .... my ecu does not have the knob, and I may have found my wing nut. So, as of now, it looks like just the boot and ecu brackets !!
Lo-Fi Version | Time is now: 23rd May 2024 - 12:12 PM |
