Justindrider |
Newbie ![]() Group: Members Posts: 3 Joined: 17-January 14 From: Texas Member No.: 16,896 Region Association: Southwest Region ![]() |
Hello Everyone My Name is Justin.
i picked up my first 914 this past week and i need to know how to get into the trunk without the key because the only key i was supplied with is the ignition, which doesnt match any other lock. thanks in advance for the help |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
10mm socket and a lot of extensions. Unbolt the trunk latch from the engine bay. (IMG:style_emoticons/default/smile.gif) |
Justindrider |
(IMG:style_emoticons/default/welcome.png) 10mm socket and a lot of extensions. Unbolt the trunk latch from the engine bay. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/headbang.gif) Front Trunk, sorry i should have been more specific ! |
Mike Bellis |
(IMG:style_emoticons/default/welcome.png) 10mm socket and a lot of extensions. Unbolt the trunk latch from the engine bay. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/headbang.gif) Front Trunk, sorry i should have been more specific ! Pull the bumper off and trigger the latch with a screwdriver. |
Justindrider |
(IMG:style_emoticons/default/welcome.png) 10mm socket and a lot of extensions. Unbolt the trunk latch from the engine bay. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/headbang.gif) Front Trunk, sorry i should have been more specific ! Pull the bumper off and trigger the latch with a screwdriver. will do first thing tmo!! thanks again |
David_S |
Member ![]() ![]() Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region ![]() |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
Welcome to 914world!!!
How about remove the door handle and bring it to a locksmith to make a key for it and hoping it will be the same key for the trunk also. |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,504 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Once the front bumper is removed there is a small rubber plug you need to remove from the front panel. THEN use a screw driver and pop the latch.
You mean the inside handle under the dash is locked? Are you sure? Could be a broken cable. You'll know when you get the trunk open. (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
front trunk is easy. Like Rick said. Usually the cable and lock mech gets corroded and harder to pull until one hard pull yanks it out from the set screw. Once you get the front truck open, make sure you pull the cable from the houseing and lube it and all moving parts and pivots. Once lubed, it will work like new.
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
If it's not actually locked, meaning the handle will pull somewhat, you often need another person to 'gently' push down on the hood above the lock area to release pressure on the latch. . then pull the handle. . . otherwise, it's remove the bumper. . .
what happens is the pull cable or wire actually slips in the latch assemble. . it will be clear to you once you get inside as see how it works. . |
bzettner |
Member ![]() ![]() Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Markl |
Member ![]() ![]() Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains ![]() |
sounds to me like you have the valet key - just have a locksmith cut a new master.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
If your key is red, it's the valet key and only works ignition and door. If it's black, and it only fits ignition then the key switch had been replaced. like said before, remove the rear trunk button and have a locksmith make a new one. Then again, it may just be very hard to pull.
Lo-Fi Version | Time is now: 17th June 2024 - 05:06 AM |
