How much needs to be cut off the lover valve covers, /6 is going to get DONE |
PanelBilly |
Feb 4 2014, 09:58 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Distributor went to Jerry Woods today. Yesterday I ordered the flywheel. Cams left for Webcams on Friday. I need to keep the ball rolling so everything is ready when the machine work is done in March. Checking the brain-trust for the modification that needs to be made to the covers
tomeric914 |
Feb 4 2014, 10:06 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Distributor went to Jerry Woods today. Yesterday I ordered the flywheel. Cams left for Webcams on Friday. I need to keep the ball rolling so everything is ready when the machine work is done in March. Checking the brain-trust for the modification that needs to be made to the covers None. Use the aluminum 911SC valve covers. Turbo valve covers are NOT needed. The key is to sand the valve covers flat. I use a piece of 12" x 12" marble tile with 220 grit sandpaper taped to it. No leaks for the past 2+ years. |
GeorgeRud |
Feb 5 2014, 12:18 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
If you already have the turbo lower valve covers, you just need to machine the ribs down in the area where the rear suspension arms attach. There are pics out there here room the bird boards that show the amount needed.
PanelBilly |
Feb 5 2014, 01:00 PM
I was searching bird last night and didn't see it.
mskala |
Feb 5 2014, 01:04 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I probably have my own pictures at home, but it is really not something easily
seen. For me it was necessary to go back and forth; grind a bit, check, grind a bit ... Also, if you are simply in a hurry to get going, there's nothing stopping you from using the 930 covers intact, it's just that to remove them you will need to lower the engine. So you could just put off the whole thing until the next valve adjust/oil change. |
toolguy |
Feb 5 2014, 01:20 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Here's a solution from a different direction. . . I pulled all my lower covers studs and use allen socket bolts. . makes it clean and simple. .
McMark |
Feb 5 2014, 01:56 PM
Here's a couple of not too great pictures. My technique, leave the lower covers off and then put the motor in the car and keep tweaking them until they go on. Once they go on, they'll come off as well.
Attached image(s) |
Mark Henry |
Feb 5 2014, 02:20 PM
Just mill all the ribs down to the top of the bolt holes.
Still plenty strong enough and looks the best. I'll get a pic (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
Feb 5 2014, 02:27 PM
I like my covers shaved (IMG:style_emoticons/default/smile.gif)
Attached image(s) |
worn |
Feb 5 2014, 02:49 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Looks nice Mark. I think I will go that way too. Nother excuse to overwork a too small milling machine. |
Socalandy |
Feb 5 2014, 03:05 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) shaved
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 08:50 AM |
