Paintless Dent Removal Recommendations |
RogerYellow914 |
Feb 12 2014, 01:25 AM
Member Group: Members Posts: 72 Joined: 4-December 05 From: Redlands, CA Member No.: 5,230 |
Can anyone here recommend a paintless dent removal company in the Redlands area?
914_teener |
Feb 12 2014, 09:58 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Yes......he is at the Orange County swap meet right in front.....I have his info and business card at home.
mrbubblehead |
Feb 12 2014, 10:16 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
StratPlayer |
Feb 12 2014, 12:02 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Had one come an look at my teener... Teener made of steel that presented a problem for the paintless dent remover. Their use to working on alum. cars much easier to repair. Good Luck
914_teener |
Feb 12 2014, 12:26 PM
I disagree......
I had a bad dent right on the top of the right front fender from a pair of skis. You can't tell it was there. This guy is in Orange County no Redlands though. |
Dave_Darling |
Feb 12 2014, 04:36 PM
Had one come an look at my teener... Teener made of steel that presented a problem for the paintless dent remover. He probably just didn't want to try on paint that was 30+ years old. Much easier to crack very old paint and have it blow off the panel than relatively-new paint. I've seen it happen with a 914 before. We had some PDR done on my wife's 82 SC. There was a ~3" x 8" section with tons of shallow parallel dents in it, like someone had kept opening a door into the car over the years. They took it out to the point where you have to know exactly where it was, and have good light in order to find it. We were quite happy with the results. But again, nowhere near Redland. --DD |
JeffBowlsby |
Feb 12 2014, 07:14 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The guy I watched do it used a tool that looked identical to the thin/flat end of a paint can opener and just brute force muscled out the smallish dents from the inside with his bare hand. On my 914 with original paint, it worked great. He got excited when I told him I didn't want the inside paint surface damaged (it was a trunk lid)...so he used a nylon-coated tool. I am sure there are other techniques.
bernbomb914 |
Feb 12 2014, 07:27 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I have one in Temecula has been doing it for 20 yrs.
mrbubblehead |
Feb 12 2014, 08:51 PM
bernie, could you pm me his number? i have a little work for him. every paintless dent guy we call wont touch anything but new cars. i have a vw bus that needs some work.
ConeDodger |
Feb 12 2014, 08:59 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I highly doubt the 'excuse' that they only work on aluminum cars. How many cars do you know of that are made of aluminum and how would you explain the proliferation of paintless dent repair businesses considering that rarity?
I had a couple very small dents repaired a few years back by a guy in Cameron Park California whose main business was instructing others on how to do it. There is no trace of the dents. In fact, I can only recall one of the general areas of those dents. It works! (IMG:style_emoticons/default/biggrin.gif) |
mrbubblehead |
Feb 12 2014, 09:35 PM
yes there miracle workers for sure. IF you can find one that willing to work on classic cars.
euro911 |
Feb 12 2014, 11:26 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I'm looking for someone who does dent-less paint removal
(IMG:style_emoticons/default/popcorn[1].gif) |
914_teener |
Feb 12 2014, 11:32 PM
Dent Rejuvenator
888-302-Dent He is mobile but usually he works at the Orange County Fair in Costa Mesa. He fixed a bad dent on the teener....was concerned a little about the paint but now you cant tell. |
76-914 |
Feb 13 2014, 08:51 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm a LMF. My neighbor across the street does this for the dealers and luckily me too! He's saved my ass a few times. Just be sure that the area that needs repair doesn't have any bondo on it. It doesn't behave like metal. (IMG:style_emoticons/default/dry.gif) Also, do the prep work yourself. i.e. remove the headlight bucket or anything else that would prevent them from having open access. It shouldn't matter to the tech if it's old or new. Old cars have thicker metal but it is more malleable. New cars have thin metal but the metal is much harder. Bubblehead PM me.
0396 |
Feb 13 2014, 05:18 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I'm a LMF. My neighbor across the street does this for the dealers and luckily me too! He's saved my ass a few times. Just be sure that the area that needs repair doesn't have any bondo on it. It doesn't behave like metal. (IMG:style_emoticons/default/dry.gif) Also, do the prep work yourself. i.e. remove the headlight bucket or anything else that would prevent them from having open access. It shouldn't matter to the tech if it's old or new. Old cars have thicker metal but it is more malleable. New cars have thin metal but the metal is much harder. Bubblehead PM me. Can you please pm me the info too, thanks (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:01 PM |
