Sloppy gear shift, really sloppy gear shift |
cal914 |
Feb 16 2014, 02:03 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
When my 1970 rear shift 914 is in neutral the gear shift is so floppy you struggle to find a gear,also when cold it goes into second[once you find it ] nicely after a little while you struggle big time to get into gear
thanks |
GeorgeRud |
Feb 16 2014, 02:53 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
First step is to replace all the nylon bushings and cups between the shift knob and the transmission. The early 4 cylinder tail shift transmission has the most connection points, so the gearshift does require quite a lot of monkey motion to actually shift the gears in the transmission.
There are plenty of options, all are much more expensive than replacing the bushings and adjusting the linkage. |
Cap'n Krusty |
Feb 16 2014, 03:15 PM
The FIRST thing to check is the ball cup under the shift lever. Most common failure, and the easiest to fix.
The Cap'n |
mepstein |
Feb 16 2014, 03:24 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The FIRST thing to check is the ball cup under the shift lever. Most common failure, and the easiest to fix. The Cap'n (IMG:style_emoticons/default/agree.gif) Mine was broken and it's a super quick repair. |
bdstone914 |
Feb 16 2014, 09:45 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The FIRST thing to check is the ball cup under the shift lever. Most common failure, and the easiest to fix. The Cap'n (IMG:style_emoticons/default/agree.gif) Mine was broken and it's a super quick repair. And when you pull the shifter check the plate in the shifter for wear. I checked three of them when I went to sell one and found two of them had excess wear if the plate. I might be able to get you a picture of a bad one. Bruce |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:34 AM |
