Accelerator Cable, Too Short? |
Grump |
Mar 12 2014, 12:22 PM
Member Group: Members Posts: 167 Joined: 26-April 06 From: Charlottesville Va. Member No.: 5,930 Region Association: None |
I must be missing something. This new cable from Pelican appears to be too short. The adjustment at the pedal end is maxed out. The pedal itself is all the way back against the stop. I'm not sure if this is the correct hole but I see no other option. Pelican's part number checks out. Anyone have any ideas or solution? Thanks
'73-914kid |
Mar 12 2014, 12:38 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Does the sheathe mount up to the plenum without issue? If the cable sheathe mounts up to the plenum without much issue, you most likely wrapped the throttle cable around the clutch cable at the front of the tunnel when installing the throttle cable.
914_teener |
Mar 12 2014, 12:58 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Grump |
Mar 12 2014, 01:02 PM
I pulled it completely out and It's doesn't appear hung up on or wrapped around the clutch cable. Maybe if I pull both cables and put accelerator in first. I just can't see where those extra inches would come from.
Grump |
Mar 12 2014, 01:03 PM
The sheath will not come close to the plenum.
'73-914kid |
Mar 12 2014, 01:11 PM
Ah, okay, it sounds like its getting hung up on something underneath the engine tin. Make sure you have the cable running the most direct route possible from the tube at the firewall up to the grommet.. It's not a super smooth transition I must say..
Grump |
Mar 12 2014, 01:16 PM
That's why I asked it it was the correct hole in the tin. The angle seems pretty acute.
Grump |
Mar 12 2014, 01:25 PM
jimkelly |
Mar 12 2014, 01:29 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
the cable should be 101" from tip to tip - i believe.
TheCabinetmaker |
Mar 12 2014, 01:33 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
What hole is it coming thru? I can't tell from your pic.
Grump |
Mar 12 2014, 01:34 PM
The forward most on the passenger side.
Grump |
Mar 12 2014, 01:39 PM
I'll pull them both and then install the accelerator cable first. Only way to make sure clutch cable is not the cause.
TheCabinetmaker |
Mar 12 2014, 01:42 PM
I don't see it in your pic. just wires.
'73-914kid |
Mar 12 2014, 01:54 PM
Th cable is coming from the correct hole, and the cable sheath is bolted up correctly to the plenum.
I'm placing my money on it being wrapped around the clutch cable still..haha |
Jeffs9146 |
Mar 12 2014, 02:09 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Also if the housing is not fully seated on the tube at the firewall it will be short!
Grump |
Mar 12 2014, 02:20 PM
I pulled both cables. Installed the accelerator cable and she is still short. Did not put clutch cable back. The black outer sheath is up tight against the bulkhead. It does measure 101 inches as jimkelly said it should. I only have 5 threads going into the pedal coupling. Don't want to loosen it more. It wouldn't be enough anyway.
JawjaPorsche |
Mar 12 2014, 02:45 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I know this sounds obvious but make sure the cable has the most direct route to the throttle after it comes out of the engine tin hole. I made that mistake. (IMG:style_emoticons/default/headbang.gif)
Grump |
Mar 12 2014, 02:57 PM
The outer sheath connects to the plenum as it should so routing it another way will not give me more cable. Outer casing appears to be okay.
Jeffs9146 |
Mar 12 2014, 03:18 PM
Maybe you got a 6 cable!?
Grump |
Mar 12 2014, 03:26 PM
I'll check with Pelican. The only numbers on the cable are "Made in Poland 424 230 3313".
Lo-Fi Version | Time is now: 9th June 2024 - 02:22 AM |
