Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
Hi All -
I am going to use a 911 heated window switch to control the fan on my oil cooler. I am trying to verify the different tabs on the back of the switch. Here is a diagram of the back: ![]() I am guessing that the numerical definitions are standard for all porsche switches - but I dont want to burn up the switch or wiring by making this assumption. Here is how I think things should go: 31 = Ground 58 = light inside the switch <-- is this + or - ? 15 = keyed power I = Load/Accessory #1 III = Load/Accesory #2 Can anyone verify? Also, is #58 a positive or negative lead? When installing a standard off the shelf FLAPS rocker switch, the lead to make it illuminate is negative. However, those types of switches do not have a ground - they just interrupt the power lead to the accessory. On a side note, this is a single postion pull switch - weird that is has what appears to be two load "outputs". Thanks a million for any help!! Scott S |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Hi All - I am going to use a 911 heated window switch to control the fan on my oil cooler. I am trying to verify the different tabs on the back of the switch. Here is a diagram of the back: ![]() I am guessing that the numerical definitions are standard for all porsche switches - but I dont want to burn up the switch or wiring by making this assumption. Here is how I think things should go: 31 = Ground 58 = light inside the switch <-- is this + or - ? 15 = keyed power I = Load/Accessory #1 III = Load/Accesory #2 Can anyone verify? Also, is #58 a positive or negative lead? When installing a standard off the shelf FLAPS rocker switch, the lead to make it illuminate is negative. However, those types of switches do not have a ground - they just interrupt the power lead to the accessory. On a side note, this is a single postion pull switch - weird that is has what appears to be two load "outputs". Thanks a million for any help!! Scott S Get yourself a cheap digital multi meter (under 8$ at harbor Freight) then using ohms scales, check across various terminals switch off & on. If open switch closed and zero or just a few ohms switch on you'll know. Barefoot |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
If this were my project, I'd put a temperature switch in the oil line and activate the fan through a relay. Simple, effective, and it doesn't rely on the driver (who may have other things to do besides watching the temp gauge) to switch it on.
The Cap'n |
Lo-Fi Version | Time is now: 13th July 2025 - 08:02 PM |
