> Old bearing RACE, or a spacer on this 911 hub?, I'm thinking bearing...but want to be sure.
CptTripps
post Mar 27 2014, 12:02 AM
:: Punch and Pie ::
I'm thinking this is the remnants of an old bearing, but before I go yanking it off of there, can I get someone to opine on it?
This is the outer hub from a 911. Just want to double-check with people more knowledgable than I am.
jcd914
post Mar 27 2014, 12:12 AM
Yes, that is a race from the rear wheel bearing.
Jim
CptTripps
post Mar 27 2014, 12:45 AM
:: Punch and Pie ::
That makes things a bit easier. Thanks!
CptTripps
post Mar 27 2014, 07:35 AM
:: Punch and Pie ::
...now I just need to figure out how in the hell I'm going to get it off!
bdstone914
post Mar 27 2014, 07:46 AM
bdstone914
QUOTE(CptTripps @ Mar 27 2014, 06:35 AM) *
I grind them thin with an angle grinder and crack them with a sharp chisel.
Cap'n Krusty
post Mar 27 2014, 08:39 AM
Cap'n Krusty
I insert a medium size properly sharpened chisel between the hub and the race and move it far enough to get a puller in there. It should be on there pretty tight, and that fit should continue all the way to the end. If it doesn't, the hub's no good.
The Cap'n
post Mar 27 2014, 08:45 AM
Eric (PMB)has a video on that exact thing at his website. He does it with a cold chisel.
McMark
post Mar 27 2014, 09:13 AM
914 Freak!
Air chisel, as long as your careful and pay attention. Takes about 15 seconds.
(IMG:http://www.914world.com/bbs2/uploads_offsite/diytoolshopper.com-419-1395933205.1.jpg)
r_towle
post Mar 27 2014, 03:19 PM
Custom Member
I have always found that heating up everything on the stove makes it easier to separate.....
If you try that, make sure its really clean.
cooking car grease smells quite a bit.
You need leather gloves and have all your tools ready for removal also.
Wife never likes it....
Rich
- Lo-Fi Version Time is now: 26th November 2026 - 09:03 AM
