smarens |
Member ![]() ![]() Group: Members Posts: 69 Joined: 15-March 14 From: Michigan Member No.: 17,121 Region Association: None ![]() |
- I did 20 searches, couldn't find what I need, I'm sure it is in here I just might not be good enough to find it
-what is correct numbers for 914 Mahle Wheels? -how concerned should I be about cracks (now or in the future if there are none showing now)? -is there any issues to get them to balance? thanks guys |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
914 361 015 00
Since they are pressure cast, being bent is easier and I haven't seen one cracked unless someone really clobbed a curb or such. If they are straight and true they should be no problem to balance with stick-on weights |
smarens |
great thank you SLITS for providing info
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Mahles are relatively soft, so make sure they are straight before mounting tires... I had 8 of them and 3 were out of round or wobbled
but looked fine.. Best looking stock wheel imho |
smarens |
I agree, in IMHO best looking wheel, the ones I found have tires mounted on them, what do I do if they are not straight?
SLITS |
sixnotfour |
if they balanced out they are fine......otherwise..
Attached image(s) ![]() |
smarens |
very inventive use, very cool also
Lo-Fi Version | Time is now: 10th June 2024 - 11:16 PM |
