FS: Porsche 901 911 914 7:27 Sportsmatic Ring and Pinion Gear Set, Great condition |
gcrotvik |
Apr 4 2014, 11:54 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I was going to use this ring and pinion in my 914/4 transmission rebuild but I have decided that I will use the stock 914 gearing. The pinion shaft will need to be milled in length to fit. CMS in California (http://www.californiamotorsports.net) has the ability to mill the pinion to the proper length.
Asking $400.00 plus shipping (CONUS) Thanks for looking! Greg Attached image(s) |
gcrotvik |
Apr 5 2014, 08:55 AM
Pictures added.
gcrotvik |
Apr 8 2014, 06:37 PM
Offers??
0396 |
Apr 8 2014, 06:48 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I was going to use this ring and pinion in my 914/4 transmission rebuild but I have decided that I will use the stock 914 gearing. The pinion shaft will need to be milled in length to fit. CMS in California (http://www.californiamotorsports.net) has the ability to mill the pinion to the proper length. Asking $400.00 plus shipping (CONUS) Thanks for looking! Greg Please expand on calif work..." Mill the pinion to proper length " Inquisitive minds (IMG:style_emoticons/default/smile.gif) |
gcrotvik |
Apr 8 2014, 09:10 PM
I was going to use this ring and pinion in my 914/4 transmission rebuild but I have decided that I will use the stock 914 gearing. The pinion shaft will need to be milled in length to fit. CMS in California (http://www.californiamotorsports.net) has the ability to mill the pinion to the proper length. Asking $400.00 plus shipping (CONUS) Thanks for looking! Greg Please expand on calif work..." Mill the pinion to proper length " Inquisitive minds (IMG:style_emoticons/default/smile.gif) The pinion shaft is longer than the standard 7:31 901/914 pinion shaft. To make this pinion work in a standard 901/914 trans case, the length needs to be shortened and the end remilled. I'm not an expert so this is the "simple" explanation. |
Lo-Fi Version | Time is now: 9th June 2024 - 11:19 PM |
