fduval |
Newbie ![]() Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada ![]() |
Hi , I am new to the 914 ownership, just bought the car from member KADUKU !
The rear end of the car is kind of very soft, I guess the rear shocks need to be replaced, what do you guys recommend for street use . The car is a 1973 with a 2 liter engine. Thanks |
smarens |
Member ![]() ![]() Group: Members Posts: 69 Joined: 15-March 14 From: Michigan Member No.: 17,121 Region Association: None ![]() |
I'm in the same boat, are you looking at doing just shocks or springs also? I've see a lot about not using KYB, good things about Bilstein and upgrading to 100lb springs over stock 90lb, I'm thinking of doing mine myself but need to get a spring compressor, sorry to not have expert advice but that is just what I have read so far
fduval |
I'm in the same boat, are you looking at doing just shocks or springs also? I've see a lot about not using KYB, good things about Bilstein and upgrading to 100lb springs over stock 90lb, I'm thinking of doing mine myself but need to get a spring compressor, sorry to not have expert advice but that is just what I have read so far I guess I should do both ! 100 lbs spring seems to be a good improvement |
Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
The upgrade to 100lb springs is common & as for the shocks I'd go with Bilstein. I prefer them over either Boge & Koni for daily use, but that's just me. |
fduval |
(IMG:style_emoticons/default/welcome.png) The upgrade to 100lb springs is common & as for the shocks I'd go with Bilstein. I prefer them over either Boge & Koni for daily use, but that's just me. Thanks for the welcome Johny |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,956 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I did it myself with boge's and 100 springs and dropped by my local mechanic and he compressed the springs for no charge. Took him 2 minutes.
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
If you want a really good setup, get a set of adjustable perches, springs and shock from ground control.
Based on your application they will calculate exactly what you need. I also have a set of stock "barely used" springs, and a set of new weltmeister 180lb springs that I dont need. I even have a decent set of Koni adjustable shocks, but messed up the threads at the top of one of them. |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 125,935 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Koni - Koni has their Yearly Sale going on right now
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,410 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Lots of auto parts stores will lend spring compressors, that's what i did
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
I did it myself with boge's and 100 springs and dropped by my local mechanic and he compressed the springs for no charge. Took him 2 minutes. (IMG:style_emoticons/default/agree.gif) This is what I did. Just make sure your control arm bushings aren't shot. Otherwise all for not....... doesn't matter what shock you use. |
saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,015 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
I am very happy with Billsteins for my street/DD car.
I stuck with my stock springs. I highly recommend replacing your springs "while you are in there" as I have noticed some sag in the rear of the car. I'm going to pick up a new set of springs to be installed next time I drop the trailing arms. For a street car I think 80-100 lb springs with a good set of shocks is a nice setup. |
carr914 |
I'm in the same boat, are you looking at doing just shocks or springs also? I've see a lot about not using KYB, good things about Bilstein and upgrading to 100lb springs over stock 90lb, I'm thinking of doing mine myself but need to get a spring compressor, sorry to not have expert advice but that is just what I have read so far Lots of auto parts stores will lend spring compressors, that's what i did You don't need Spring Compressors! Take off bolts in Trunk, Jack up the Rear of the car, the Springs & Shocks will drop. Un-do bottom Shock Bolt, take off. Reverse the proceedure & you are done! |
mepstein |
I'm in the same boat, are you looking at doing just shocks or springs also? I've see a lot about not using KYB, good things about Bilstein and upgrading to 100lb springs over stock 90lb, I'm thinking of doing mine myself but need to get a spring compressor, sorry to not have expert advice but that is just what I have read so far Lots of auto parts stores will lend spring compressors, that's what i did You don't need Spring Compressors! Take off bolts in Trunk, Jack up the Rear of the car, the Springs & Shocks will drop. Un-do bottom Shock Bolt, take off. Reverse the proceedure & you are done! I needed them compressed to get the bolt back on the shock with the new springs. I could get it close but after a half hour of trying I drove the 2 miles to the shop and got it done. |
carr914 |
I'm in the same boat, are you looking at doing just shocks or springs also? I've see a lot about not using KYB, good things about Bilstein and upgrading to 100lb springs over stock 90lb, I'm thinking of doing mine myself but need to get a spring compressor, sorry to not have expert advice but that is just what I have read so far Lots of auto parts stores will lend spring compressors, that's what i did You don't need Spring Compressors! Take off bolts in Trunk, Jack up the Rear of the car, the Springs & Shocks will drop. Un-do bottom Shock Bolt, take off. Reverse the proceedure & you are done! I needed them compressed to get the bolt back on the shock with the new springs. I could get it close but after a half hour of trying I drove the 2 miles to the shop and got it done. If you had sat in the Trunk, your weight would have compressed the Springs and you would have gotten the nut on |
injunmort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States ![]() |
I did this today, bilsteins to replace kyb, s and 100lbs. springs. set clip second to top position on shock body and assemble, no spring compressor needed. no spring compressor needed to disassemble the kyb's either.
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
Are you guys replacing the bump stops and if so where did you get them?
John |
Paragon |
Newbie ![]() Group: Members Posts: 49 Joined: 6-February 03 From: Corpus Christi, Texas Member No.: 255 Region Association: Southwest Region ![]() |
injunmort |
I reused the bumpstops as they were ok
Mr Pharmacist |
Member ![]() ![]() Group: Members Posts: 69 Joined: 15-September 09 From: United Kingdom Member No.: 10,807 Region Association: England ![]() |
I'm in the same boat, are you looking at doing just shocks or springs also? I've see a lot about not using KYB, good things about Bilstein and upgrading to 100lb springs over stock 90lb, I'm thinking of doing mine myself but need to get a spring compressor, sorry to not have expert advice but that is just what I have read so far Lots of auto parts stores will lend spring compressors, that's what i did You don't need Spring Compressors! Take off bolts in Trunk, Jack up the Rear of the car, the Springs & Shocks will drop. Un-do bottom Shock Bolt, take off. Reverse the proceedure & you are done! I needed them compressed to get the bolt back on the shock with the new springs. I could get it close but after a half hour of trying I drove the 2 miles to the shop and got it done. If you had sat in the Trunk, your weight would have compressed the Springs and you would have gotten the nut on Thanks for that handy hint - tried it earlier and worked a treat - much easier than using spring compressors!! Any handy hints for changing the front inserts? (sorry for the hijack but did a quick search and couldnt seem to find a post on how to go about this) Thanks |
Paragon |
QUOTE Any handy hints for changing the front inserts? (sorry for the hijack but did a quick search and couldnt seem to find a post on how to go about this) Thanks Easy. We wrote this years ago...kind of generic but I think you'll get the idea: https://www.paragon-products.com/kb_results.asp?ID=1 |
Lo-Fi Version | Time is now: 6th July 2025 - 03:37 PM |
