bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,039 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I heard this can be done but have not tried it. The differences are that the 924 switch has ony one rider for the horn and has the 4 and 5th wires swapped in the loom. I do not think this matters as those two are bridged when the left turn signal is applied.
Any body tried It? Attached thumbnail(s) ![]() ![]() |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
I bought a 924 switch and installed it about 9 years ago. It works great but I can't remember what I had to do. I seem to recall trimming some of the plastic wire channels off that weren't needed or didn't fit. It took a little work but it eventually fit. I realize I'm not much help here but it WILL work.
Cheers, Elliot |
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
Yes you can... I wrote this about 14 years ago.
http://www.pelicanparts.com/techarticles/9...tric_washer.htm |
bdstone914 |
Yes you can... I wrote this about 14 years ago. http://www.pelicanparts.com/techarticles/9...tric_washer.htm Karl, Thanks but that is for the wiper switch not the turn signal switch. Elliot, The connector seems to be the same on the one I have. But if you did it I guess it works. Bruce |
Qarl |
Karl, Thanks but that is for the wiper switch not the turn signal switch. LOL... Time for me to stop drinking my Scotch for the night. (IMG:style_emoticons/default/beer3.gif) You can hit me with this now! (IMG:style_emoticons/default/chair.gif) |
Qarl |
Yes you can... certain years.
According to Jeff Bowlsby's spreadsheet https://bowlsby.net/914/Classic/zTN_Gen_914...Interchange.xls It shows... Part Name VW/Porsche Part Number Bosch Part Number Porsche 914 Other vehicles using the same part number [SPN substitute part number] Turn signal switch 311.953.513B 1970-71 VW 1968-70 Beetle/Ghia, VW Type 3 68-69 Turn signal switch 111.953.513C 1971 VW 1971 Beetle Turn signal switch 914.613.913.14 1972-74 VW 1972-79 Beetle, Porsche 1976-80 924 [SPN 111.953.513F] Turn signal switch 914.613.913.15 1975-76 VW 1975-76 Rabbit, VW 1972-79 Beetle, Porsche 1977-81 924 [SPN 111.953.513F] |
Qarl |
And if you have a copy of Hussey's "Tech Tip 700", there's info about it in there.
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Just FYI that book says the 1975-76 switches do not interchange with any other year 914 but are a direct swap for 1977-81 924's. Don't see any other notations for other years related to the 924 switch. Something else I didn't know!
Elliot Cannon |
Yes you can... I wrote this about 14 years ago. http://www.pelicanparts.com/techarticles/9...tric_washer.htm Karl, Thanks but that is for the wiper switch not the turn signal switch. Elliot, The connector seems to be the same on the one I have. But if you did it I guess it works. Bruce Sorry Bruce. I think mine was a wiper switch as well. DOH!! I haven't been drinking scotch, I just can't remember much from 9 years ago. |
Lo-Fi Version | Time is now: 13th July 2025 - 08:36 PM |
