Rear roof latches, Having trouble keeping them together. |
wndsnd |
Apr 28 2014, 07:55 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I am on my third set of rear latches. It seems that flex is putting too much pressure on them and I am having trouble keeping the c clips on them. When the clips fall off the latch vibrates apart and falls behind the seat.
I am wondering if others are having that problem and how you fixed it? I am contemplating welding a washer on the ends but I suspect it might be cast. Is there another fastener I can use to hold them together? Thanks John |
r_towle |
Apr 28 2014, 07:56 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
What??? Post a pic... Rich |
URY914 |
Apr 28 2014, 08:04 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
This is a new one for me. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/confused24.gif)
wndsnd |
Apr 28 2014, 08:07 PM
I know, I am having trouble figuring it out. The c clip is on a pin that should not have a horizontal load on it, only vertical, but yet there is a lot of pressure on them.
orthobiz |
Apr 28 2014, 08:09 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I haven't seen that. Get a refinished set from Bruce bdstone914.
Also, make sure no one put some kinda ring or tubing on the hook that lives on the roof. Recently I replaced the rear gasket from 914rubber, the one on the roof in the back with the fuzzy strip. Man, what an upgrade! I had forgotten what a quiet 914 was like without squeaks and rattles. Paul |
wndsnd |
Unless they are assembled with the wrong clip to begin with......
wndsnd |
Apr 28 2014, 08:11 PM
I haven't seen that. Get a refinished set from Bruce bdstone914. Also, make sure no one put some kinda ring or tubing on the hook that lives on the roof. Recently I replaced the rear gasket from 914rubber, the one on the roof in the back with the fuzzy strip. Man, what an upgrade! I had forgotten what a quiet 914 was like without squeaks and rattles. Paul Did that. Bruce's fell apart too. Interesting about the roof. I have not checked that. |
JmuRiz |
Apr 29 2014, 07:26 AM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Might be a worn out set of seals like Paul said...squished seals could allow play.
bandjoey |
Apr 29 2014, 09:39 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Wrong roof version? Yes, add a piece of rubber vac hose to the pin and it tightens up the roof considerably. Also, new Mikey914rubber roof seals ?
JRust |
Apr 29 2014, 01:28 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/WTF.gif) So the clip itself just comes apart? I've never had one do that before. Hell I've had trouble getting them apart when I was trying to (IMG:style_emoticons/default/blink.gif)
bdstone914 |
Apr 29 2014, 02:36 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
(IMG:style_emoticons/default/WTF.gif) So the clip itself just comes apart? I've never had one do that before. Hell I've had trouble getting them apart when I was trying to (IMG:style_emoticons/default/blink.gif) The shaft for the clip has a shallow groove and the hook is a sloppy fit. I had a clip come off on one with new seals that were very hard to compress. Maybe a Palnut push on fastener would work better. They are the type used on kids wagon wheels that have locking fingers and are a one time use. http://images2.mcmaster.com/Contents/gfx/l...ng?ver=19733168 http://www.mcmaster.com/#push-nuts/=rr26qk Bruce |
wndsnd |
Apr 29 2014, 03:49 PM
I haven't had time to look at it again, but I was so focused on the latch, I did not tackle the real problem.
I did replace the seals on the roof, I will look at the roof, there is obviously too much pressure for the latches. Thanks Bruce, Good idea, I will look at those. And Thanks guys for getting me refocused. John |
Chris Pincetich |
Apr 30 2014, 01:43 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I had this happen to my re-stored latches. Perhaps the new paint/powder coat reduces the effectiveness of the groove that holds the clip in.
I re-installed the clip with just a dab of glue, and it has not given me any problems since. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 02:06 PM |
