Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
Help please guys -
1973 914 is really difficult to downshift from third to second when warm - seems to be far easier when cold, but after a run it gets much harder, feels like the clutch isn't engaging properly.. Clutch or bushing problem do you think? Is the clutch adjustable? I don't think that my cable tube has broken.. |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
You might have meant disengaging?? Well, as long as an amp/speaker/port/wire harness isn't interfering, (IMG:style_emoticons/default/shades.gif) a clutch adjustment is the first thing to check. The cable may be stretching; check pedal free play when cold and see if it increases when warm/hot. Start there.
Doesn't sound like a moving tube if the issue goes away every time it cools down... |
Rod |
Haha. Nothing audio related interfering!! (IMG:style_emoticons/default/driving.gif) yes I did mean disengaging as you point out!.. Ok I'll start with looking at the clutch cable - is there an adjustment guide in forum??
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,758 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
There's a special Delrin nut on the clutch cable and I have poor luck with it over the years, I adjust the clutch now and then when it's more reluctant to disengage. I've double nutted it in the past and always put a fresh nut on any new cable. But I think I've experienced what you're talking about: it's like it wants to hold onto third gear and not let you out of it, right?
Also, if I'm downshifting from third into second I often double clutch out of habit from all the cars I've owned in the 70's. Once you've ever had an Alfa you get quite good at it and it's become second nature. Paul |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Heat could raise clutch issues if there's some contamination (i.e., gear oil) on the disc. I might be inclined to look at the 2nd gear synchro if the clutch is OK. BTW, older Alfas used Porsche style synchros, and they're notorious for failing. BTDT with a GTV. As for downshifting as an aid for slowing down, remember that brakes are cheaper than trannys.
The Cap'n |
Lo-Fi Version | Time is now: 9th July 2025 - 01:29 PM |
