Quick Clutch / TO Beariing Question |
andrew15 |
May 19 2014, 04:27 AM
Newbie Group: Members Posts: 40 Joined: 10-April 10 From: Thunder Bay, ON Member No.: 11,594 Region Association: None |
I've rebuilt my pedal cluster and am installing a new clutch cable.
With no cable connected, the pedal goes to the floor With the cable installed, it takes up all the slack between the throw out bearing and the clutch If that's the case, is the throw out bearing always in contact with the clutch diaphragm? Thanks Andrew M |
bulitt |
May 19 2014, 06:00 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
No, TO bearings should not be riding on the clutch fingers constantly. They aren't designed to spin at high rpm's for extended periods. Adjust your cable so there is slight free play.
Heres a procedure link- http://www.914world.com/bbs2/index.php?sho...tch++adjustment |
edwin |
May 19 2014, 07:05 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
I always wondered why the ones in Vw and Porsche aren't meant to be in contact but most new cars use one that is always in contact. Most engines don't see rpm that would be a problem for even cheap bearings. Or am I over thinking it?
bulitt |
May 19 2014, 07:24 AM
I always wondered why the ones in Vw and Porsche aren't meant to be in contact but most new cars use one that is always in contact. Most engines don't see rpm that would be a problem for even cheap bearings. Or am I over thinking it? I think you hit it correctly. Newer GM and Mustangs have constant contact hydraulic bearings which ride against the fingers. They just never see extended high rpm's. I read some of these cars are having failures in Germany on the Autobahn. Compared to domestic TO bearings from the 70's the 914 version is a nice design IMHO. Seems my 1971 Z28 was always eating bearings. They were just stamped steel with some balls inside. I could shift the Muncie without using the clutch. Just moved the shifter so the gears were touching and once they spun up would pop into gear. |
bdstone914 |
May 19 2014, 04:09 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Yes the spring on the clutch pedal should push the pedal down when the cable is not attached. You should have about one inch of play in the pedal before it starts to disengage the pressure plate.
Dave_Darling |
May 19 2014, 05:56 PM
No, TO bearings should not be riding on the clutch fingers constantly. Yes, they should. The spring that pulls the clutch pedal down to the floor takes up the slack in the system, and keeps the t/o bearing in contact with the pressure plate. Much or all of the free play in the 914 clutch pedal should be in the "pulling the pedal up from rest". --DD |
HalfMoon |
May 19 2014, 07:42 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
I've noticed if I allow to much slack in my clutch cable the throwout bearing arm will come into contact with the spinning plate. Not good. A wee bit of tension shuts it up and puts the pedal at about a third for disengagement.
Anyone else have that? Oh, mines not stock so that probably has alot to do with things. Renegade sb convert with the kevlar clutch. PO did the convert so no idea what the pressure plate is although the TOB is deffinately 914 (I had the trans out over the winter and took it up to the Dr. for a 1st gear block and a ratio change throughout). |
Lo-Fi Version | Time is now: 10th June 2024 - 02:20 AM |
