Vellios Oil Tank NPT Size |
patssle |
May 25 2014, 08:05 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Anybody know if the input/output of the Vellios oil tank NPT fittings are 3/4" or 1"?
Thanks. |
Steve |
May 26 2014, 07:20 PM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I'm looking at his old catalog and it says 914/6 Oil Tank with -12 AN Oil Line Connections.
Made from Vinyl Ester (will not rust) Part number OT02 It listed for $450.00 back in January 1991 |
Justinp71 |
May 27 2014, 05:43 PM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
not sure of the NPT thread size, but I know mine has AN-12 in and AN-16 out (with its adapters to the tank)... I know the outlet was very large.
sixnotfour |
May 29 2014, 09:04 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
3/4 pipe threads, same size as -12, you can get a -16 an to 3/4 pipe if so inclined..
patssle |
May 30 2014, 08:42 AM
The tank is indeed 3/4 NPT. However that does not equal its size - measuring the ID it comes out to .89" which is why I was so confused. Also while -12 AN is supposedly the same size - the ID of the NPT to AN fitting is actually a tad smaller on the AN side. Whereas the -16 AN is slightly bigger.
It was very frustrating to find out the size of the NPT - measuring does not give an accurate account because the actual size is bigger than it says! |
Lo-Fi Version | Time is now: 8th June 2024 - 12:26 PM |
