transmission leaks, what to change out? |
jacksun |
Jul 11 2014, 09:11 AM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
HI,
the transmission had a leak at the rear bottom nut. now there are more... first please... what size tool would I need for "A" and "B"?? "C" is where a drop was hanging that I wiped off. "D" looks to be the source of those drips nearby. from looking at the pelican diagram, I am hoping that numbers 6 and 17 are all I need to buy?? not sure about "C" as I can not determine what gasket/seal I should buy from the diagram. your thoughts please and any tips. thanks randal |
zambezi |
Jul 11 2014, 11:22 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
The tool is a 17mm allen. I have a Hazet wrench with a 17mm allen on one side and a 21mm box end on the other. You can buy just a 17mm allen socket to fit your ratchet.
jacksun |
Jul 11 2014, 04:45 PM
thanks for the info
r |
swooshdave |
Jul 11 2014, 04:48 PM
Member Group: Members Posts: 184 Joined: 11-June 14 From: Portland Member No.: 17,475 Region Association: Pacific Northwest |
That looks too clean to actually be in your car. (IMG:style_emoticons/default/biggrin.gif)
jacksun |
Jul 12 2014, 04:46 AM
it's not "actually" in the car
Dr Evil |
Jul 15 2014, 10:15 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I doubt that 6 is the culprit. Likely speedo drive O-ring, O-ring for shifter console (17), and are you sure it is not engine oil? Input shaft seal can end up down there, but so can engine oil.
Jon H. |
Jul 15 2014, 03:06 PM
Member Group: Members Posts: 237 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
Just buy the whole transmission gasket set and change everything. Or just change the gaskets/O-rings that you need and save the rest. It's not to difficult to re-seal the tranny.
Jon H. |
Dr Evil |
Jul 15 2014, 03:20 PM
If you are not in a hurry, I can send you the two O-rings. I have a few spare ones. PM me and I can maybe get them out tomorrow.
Lo-Fi Version | Time is now: 7th June 2024 - 04:14 PM |
