Thermostat, Thermostat |
partwerks |
Jul 13 2014, 09:12 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Using the water logs instead of the water pump on the LS, I wonder what/if/where the thermostat is being used, or how is it being implemented?
Mike Bellis |
Jul 13 2014, 09:25 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
What water pump are you running?
I'm running an electric on my conversion. I have a thermostat with holes drilled in it. I could get away without one but it's a PITA to pull it out now. The thermostat mostly helps to warm up the engine faster and keep it at operating temp. |
bobo914 |
Jul 13 2014, 09:43 AM
Newbie Group: Members Posts: 12 Joined: 11-March 06 From: Riverside, CA Member No.: 5,708 |
Using the term "water logs" it sounds like you are talking about the Renegade set up. They use an electric water pump that has the thermostat housed inside.
partwerks |
Jul 13 2014, 01:23 PM
At this point I was just going to try and make the water logs, but the mechanic was inquiring about what route is usually taken for the thermostat.
I wish I had a pic of the back side of the logs. I'll probably have to add on another place for the heater. I have a junk water pump to pattern off of. Any places in specific to get the electric water pump at, or exactly what type?? I may as well check out as many places I can for the best deal. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:16 AM |
