-6 conversion exhaust gaskets., Help me worry this to death |
eyesright |
Jul 18 2014, 08:29 AM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
I bought a 2L -6 conversion project that I am completing. It came with headers and a Magnaflow exhaust. The head exhaust port is 32 mm (1 1/4"), the new gasket from PP is 36mm (1 3/8"), the header is 38mm (1 1/2").
The gasket will obviously crush on the head but doesn't look like the copper crush area will contact the rim of the header. Magnaflow web site doesn't offer gaskets (and doesn't even offer Porsche in the drop down). PP only lists the one gasket size and isn't open for calls yet. Option A: play dumb, bolt together and see what happens... Option B: clean up road grime and oil from exhaust system while waiting to hear forum comments. Thanks everybody. |
SLITS |
Jul 18 2014, 09:00 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
From the head port .... as long as the gasket is larger than the port and the down pipe of the headers is larger, you will not interfere with exhaust port flow.
Bolt it up and see if it leaks. If it leaks, you have more work to do. If it doesn't leak, it's not a problem. My opinion and $0.05. |
Maltese Falcon |
Jul 18 2014, 10:18 AM
Advanced Member Group: Members Posts: 4,692 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
...your next concern is loosing the header wrap.
I'm looking at about 6 to 10" of disintegrating steel in your near future (IMG:style_emoticons/default/headbang.gif) Marty |
eyesright |
Jul 18 2014, 04:17 PM
There, that's much better.
I was more worried about exhaust leak than interfering with flow seeing that the copper ring won't seat on the header metal. Anyway, PP says, "everybody uses what's in stock", so that, plus the nickel advice, I 'll bolt things up and proceed. I bet it'll work great. Thanks. ...your next concern is loosing the header wrap. I'm looking at about 6 to 10" of disintegrating steel in your near future (IMG:style_emoticons/default/headbang.gif) Marty I assume the wrap on the header was for insulation for some nearby control cable or something that will be apparent when I bolt things up. These sixes and headers are new to me. Has any one had problems with corrosion under the wrap or is there something else I need to consider? |
Jeffs9146 |
Jul 18 2014, 04:40 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I put my insulation on the cables and oil line instead of the header!
SLITS |
Jul 18 2014, 05:09 PM
With header wrap, the metal gets exceedingly hot and crystallizes.
We used it on the race cars, because the headers were a throw-away .... we had a jig to make new ones. It will take a while ... time parameters are unknown to me. |
Maltese Falcon |
Jul 18 2014, 08:17 PM
eyesright |
Jul 19 2014, 05:04 PM
HOLY KRAPPE!!! Look what I found. I'll keep this topic alive one more time in hopes that no one here will become a DAPO.
...your next concern is loosing the header wrap. I'm looking at about 6 to 10" of disintegrating steel in your near future (IMG:style_emoticons/default/headbang.gif) Marty Thanks for your heads up. I didn't think of corrosion till your caution above and was unaware of the possibility of metal failure. I'll clean the pipe up and get some high temp paint and just keep a close eye on things I guess. And I'll find some wrap for the cables if that looks like a problem. Thanks to the Forum I dodged a bullet! (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:43 AM |
