FS. FI harness. '74 L-Jet., Sold |
mikea100 |
Jul 18 2014, 08:49 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
FS. FI harness $30 + shipping.
Attached image(s) |
mikea100 |
Jul 19 2014, 06:49 PM
Can anybody help Id these? Thank you!
worn |
Jul 19 2014, 07:52 PM
can't remember Group: Members Posts: 3,162 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Black22 |
Jul 19 2014, 08:07 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Look like L-jet harnesses.
JeffBowlsby |
Jul 20 2014, 08:32 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
If they are from a 914, they look like the L-Jet FI harnesses from the 1974-75 cars.
Check the air flow meter connector - 6 pins is 1974, 7 pins is 1975. |
mikea100 |
Jul 20 2014, 06:06 PM
Thank you, Jeff! I can confirm that these are the L-Jet harnesses and one of them is for MY '74 (6 pin) and second is for '75 (7 pin). I'm attaching photo of the air flow meter connectors.
Attached image(s) |
mikea100 |
Jul 20 2014, 06:17 PM
PS. I have the injectors for L-Jet for $50. Will combine both lots for $100.
MartyYeoman |
Jul 21 2014, 01:59 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
There are 914 L-Jet harnesses and there are Bus L-Jet harnesses.
I'd be interested in the 7 pin if it's specific to the 914. I can send along a specification to confirm if needed. Marty |
mikea100 |
Jul 21 2014, 06:24 PM
MartyYeoman |
Jul 21 2014, 08:50 PM
The harness on the left is for a 914. The one on the right is for a 2.0 Bus motor.
Note that on the 914 version, the AFM connector is on the opposite end from the control module connector. On the bus version, the AFM connector exits midway along the harness between the control module connector and the injector connectors. The 914 version is also a lot longer than the bus version. In the picture on your first post, which harness is the 7 pin harness? Marty Attached thumbnail(s) |
mikea100 |
Jul 22 2014, 08:50 PM
It's a 914 harness, see picture.
Attached image(s) |
Grump |
Jul 23 2014, 06:51 AM
Member Group: Members Posts: 167 Joined: 26-April 06 From: Charlottesville Va. Member No.: 5,930 Region Association: None |
mikea100 |
Jul 23 2014, 07:29 AM
Both of them are available. I'd prefer to sell them as a package for $60 + shipping, but
can split them $40 each + shipping. |
Grump |
Jul 23 2014, 02:20 PM
I'll take the 7 pin. No need for a Bus harness. Does the harness look to be in good condition? No broken wires or burnt spots? Outer insulation in good shape? If so, send me a PM with payment info. Regards Bill
mikea100 |
Aug 2 2014, 02:43 PM
One harness left. $30 + shipping, which is $12 flat rate box.
mikea100 |
Sep 9 2014, 06:18 PM
mikea100 |
Sep 26 2014, 01:03 PM
brooks944 |
Sep 26 2014, 05:16 PM
Member Group: Members Posts: 241 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
Is the 75 harness still available?
mikea100 |
Oct 13 2014, 12:22 PM
mikea100 |
Oct 30 2014, 08:48 AM
Lo-Fi Version | Time is now: 6th June 2024 - 02:59 PM |
