worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,492 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Today at an autocross meet the car was doing great. EXCEPT that after a sharp curve there was a delay in getting power, with he engine running lean. We were running a half tank or less to save on weight and it was suggested that the problem was fuel starvation after a sharp turn.
Having looked inside the tank it don't seem so awfully likely, but it does fit the symptoms. Driving back on country roads I went across several 90 degree bends, and the same durn thing happened! (IMG:style_emoticons/default/hissyfit.gif) Any thoughts? |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Carbs or FI?
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,911 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
oops
worn |
Mike Bellis |
I would start with a new higher volume FI pump. A fuel accumulator requires a tank and a secondary fuel pump. There should be no need for an accumulator at your HP level. You should also replace the pressure regulator.
Also make sure your supply and return in the tank are not reversed. Do you have this problem with a full tank? BTW, I'm running a single pump in the front and a +300hp turbo motor and don't have this issue. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Do you have this problem with a full tank? (IMG:style_emoticons/default/agree.gif) I would start there. If it still happens with a full tank something else is going on. If it is related to fuel level in the tank, you could try to add some baffle to the tank. That would require opening the tank but should work well enough. (IMG:style_emoticons/default/smile.gif) |
worn |
Do you have this problem with a full tank? (IMG:style_emoticons/default/agree.gif) I would start there. If it still happens with a full tank something else is going on. If it is related to fuel level in the tank, you could try to add some baffle to the tank. That would require opening the tank but should work well enough. (IMG:style_emoticons/default/smile.gif) I guess I was wondering if it had happened to anyone before. It is a relatively new FI set of components, and yes, I think it does depend on fuel level. But this is a tank I treated with rust removers and rotary nuts and bolts. I ran it with a bar b q rotisserie for a couple of days and yes, I did count the nuts and bolts both ways. I was impressed by the baffles already present. Any chance the bucket for the fuel return isn't quite enough? I am running at 32 psi, which is slightly high, and I also notice how the tank is very transverse. It is right at the front wheels, so there is good reason for all of the fuel to migrate left or right. Then after the turn - disappointment! |
Mike Bellis |
I'm wondering if your supply and return are reversed. The supply is the lowest one and should not starve for fuel like you describe. The return sits about 2" above the bottom of the tank. If they were swapped, it could produce the effect you describe.
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,104 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
The tank already has some baffles in it, adding more would probably be more trouble then it is worth.
Where is your pump located? Is it an old 3 port or a new replacement? I had a similar condition but it was not due to fuel slosh but rather shifting and pinching of the fuel supply lines between the tank / filter / pump. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,013 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
We never had problems with stock tanks. I think something else is causing it other than the tank. I've even had electrical problems related to cornering forces
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
When I road raced my car with a d-Jet 1.7L I ran an accumulator fed by a low pressure pump.
Fuel in the tank sloshes around too much for the pump to maintain full pressure for the FI. |
tadink |
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California ![]() |
I've got exactly the same issue but ONLY on hard lefties, righties are al-rigthy. Baffled by this for going on a year now - it happened with my 1.7L FI and still happens with the replacement 2.0L FI. tub is a '71 - stainless lines thru the tunnel by McMark....so pretty sure they are hooked up to the correct supply / return at the tank.
I'd like to figger it out as I'm not able to ax with it the way it is.... glad I'm not the lone ranger on here with this issue! maybe I'm not crazy after all? keep those suggestions coming - its probably something! td |
d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,349 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
expensive but here is one to use almost out of the box..
tadink |
d914 |
low pressure from the gas tank.. high pressure to the fuel rails.. edelebrock, for use with their superchargers..
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I have seen the fuel slosh "chambers" that use trap doors to keep the last bit of fuel in a smaller area for the pickup.
The other way to do it is to use a low pressure in sump fuel pump to pump up to a reservoir (can be in tank or out) that dumps back to the tank (or fuel cell) with an overflow. Then a HP fuel pumps from there. That way the HP pump wont ever get starved until the very end. Using the LPFP in the tank it is less susceptible to damage from being run dry frequently. |
ChrisFoley |
where do you put it? Upstream or downstream from the existing fuel pump? It works with fuel injected set ups, yah? A fuel accumulator is a small tank (1 quart or more) fed by a low pressure pump drawing from the tank, with a return line that goes back to the tank. The return fitting is at the top of the tank so it stays filled at all times. The primary fuel injection system draws fuel from the bottom of the accumulator and returns the excess back to the accumulator. That way the high pressure FI system never sucks air unless the fuel tank is totally empty. It is well worth the investment if you're chasing trophies. (IMG:style_emoticons/default/first.gif) |
tadink |
Thanks all for the input - but I don't think we still know why the Worn (OP)'s car and my car exhibit the same fuel starvation issues on hard left corners?
is a fuel pump upgrade the way to go? any other thoughts??? td |
Lo-Fi Version | Time is now: 16th July 2025 - 05:06 PM |
