JWest Fuse Block, No Paint on the base ? |
914Sixer |
Aug 11 2014, 04:40 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I received a new JWest fuse block update but there was no paint on the mounting base. When did this happen?
Attached image(s) |
bandjoey |
Aug 11 2014, 05:09 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Possibly for good ground
pvollma |
Aug 12 2014, 08:55 AM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
I received a new JWest fuse block update but there was no paint on the mounting base. When did this happen? Make sure you insulate the spade connectors. After no problems with the installation, a few months later I lost a whole host of electrical items (gauges, turn signals, etc.) while driving. Turned out one or more of the spade connectors had been pressed down towards the base when it was installed, and finally contacted it and shorted (pardon my inelegant description, but I had my shop diagnose and fix the problem, so I'm trying to remember their description). Just make sure that there's no way a spade connector can short against the base. |
arkitect |
Aug 12 2014, 06:19 PM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Do these fuse panels with the more updated blade type fuses help? What are the advantages?
Dave |
914Sixer |
Aug 12 2014, 06:45 PM
The updated fuse block keeps you from knocking the fuses out and or breaking the cover. My fuse block was broken on one of the bases and the cover was gone. New fuse block about $35 and new cover around $25. I was half way to the price of a new style block.
I was planning to use a different spade type connector than what was provided but I am not sure if the double stack connector will work. At any rate I will heat shrink the connectors. |
Cairo94507 |
Aug 13 2014, 07:02 AM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I am installing one of these in my Six as a precautionary measure as I had issues with both of my other Sixes with the stock fuse block and the little fuses. I just think this is one area we can improve on with out it really changing the car.
SKL1 |
Aug 13 2014, 08:26 PM
Senior Member Group: Members Posts: 1,605 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Had one for quite a while and the base is not painted, just like yours. I assume they're all like that.
larryM |
Aug 13 2014, 09:05 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
have had one installed for several years - love it
what the h... does it matter what color or paint is or is not on it ???????????? - it ain't an original part it is what it is, and makers are free to do running changes and improvements in their products - even Porsche did/does that to this day |
914Sixer |
Aug 14 2014, 07:18 PM
Just asking, the last one (3 yrs ago) was painted. All the sales pictures show them painted. Seems that they quit paint awhile back.
Lo-Fi Version | Time is now: 9th June 2024 - 01:52 AM |
