Should I even be doing AutoX with a PMB 5 lug conversion? |
wndsnd |
Aug 12 2014, 10:06 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Kind of late to be asking this question.
carr914 |
Aug 13 2014, 06:13 AM
Racer from Birth Group: Members Posts: 119,045 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Why Not?
wndsnd |
Aug 13 2014, 08:20 AM
I thought I heard maybe not for Autox
Thats whI I asked. Maybe because of the way lugs are installed in hub |
ConeDodger |
Aug 13 2014, 01:39 PM
Apex killer! Group: Members Posts: 23,615 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I do.
You're not talking the drilled front rotors Eric did years ago right? |
wndsnd |
Aug 13 2014, 01:43 PM
No we just did this in February.
Woody |
Aug 13 2014, 04:07 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Are you using 911 struts? Shouldn't be a problem with 911 struts. Thats what I use. I also drilled my own rear hubs and rotors on a mill. Works great.
wndsnd |
Aug 13 2014, 04:25 PM
No 911 struts.
These are std 914 drilled and I believe the studs are pressed in from rear. Both front and rear are done the same way. |
Woody |
Aug 14 2014, 06:08 AM
Im sure its plenty strong. I highly doubt Eric would sell a product that isnt up to task.
wndsnd |
Aug 14 2014, 06:12 AM
I agree
And install was done by Tangerine. I will put my faith in these guys. I couldn't. Do any better.. John |
ww914 |
Aug 14 2014, 08:06 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Kind of late to be asking this question. I've been running rear drilled 5 stud rotors for a couple of years now doing 10 to 12 AXs a year. I did tack weld them on the inside just so they stay in place, when they loosened up a bit when I forgot to torque the nuts down once. If you do that, just make sure the wheels are on and tight before you tack them in place, so the studs are are straight. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:07 AM |
