oil cooler washers, which goes where? |
cwpeden |
Aug 23 2014, 05:17 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
So the cooler comes with 2 washers. Thick and thin.
Which one goes where. I've always put the thick one behind the cooler and used silicone to seal. But on this rebuild I didn't use silicone and it leaks. Yes, the surfaces are clean and totally silicone free. I put some grease on it to see how much squash there is on the seal and it was hardly touching. Hmm, thin washer underneath? |
cwpeden |
Aug 23 2014, 06:08 PM
10 ft lbs torque?
Bump |
colingreene |
Aug 23 2014, 06:17 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
My washers are on the outside,
i took it to 5 ft pounds and it seemed high since its such a small thread. |
ClayPerrine |
Aug 23 2014, 07:40 PM
Life's been good to me so far..... Group: Admin Posts: 15,518 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There should be no washers between the cooler and the case. If you have them there, the seals won't compress enough, which will cause them to leak.
You only need washers under the nuts. |
cwpeden |
Aug 23 2014, 07:52 PM
Hmm, PET list 2 washers and I guess I've always assembled based on the parts supplied. (when I took the engine apart) Well I learned something today. Thanks Clay
I guess if they needed spacers they would have made the bosses on the cooler bigger? Now does 10 ft lbs sound right? |
cwpeden |
Aug 23 2014, 07:54 PM
Now does 10 ft lbs sound right? Maybe should be more like 7? |
mepstein |
Aug 23 2014, 08:22 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There should be no washers between the cooler and the case. If you have them there, the seals won't compress enough, which will cause them to leak. You only need washers under the nuts. Clay is right. I've done this repair as well and when I did it, the instructions weren't very clear about the washers. I only put the rubber seals between the engine and the cooler and the washers under the bolts on the outside of the cooler and it worked perfectly. |
McMark |
Aug 23 2014, 11:41 PM
The factory manuals are pretty clear if you look carefully. (IMG:style_emoticons/default/sunglasses.gif)
Attached image(s) |
stugray |
Aug 24 2014, 12:24 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I think most of use look at the PET which is not very clear.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1408861473.1.png) And the stock "thick washers" appear to be machined which leads one to believe they are spacers. I had the same question first time. |
cwpeden |
Aug 26 2014, 12:38 AM
Thanks for the help guys.
Going to start the car car tomorrow. I cranked it over on the ground jumping from the battery. I'll assume it made oil pressure and it didnt leak. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:54 AM |
