WTB: Horn Base Plate and Connector, Broke the stupid thing... |
BeatNavy |
Sep 15 2014, 12:02 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Would any of you fine gentlemen (or ladies) have a horn base plate with which you're willing to part? Also, does anyone know where I can get the very small female connector that connects to the base plate? Trying to do one of those "simple tasks" yesterday (replacing the rubber horn return thing) I ended up a) wasting about 2 hours of time on a beautiful day, and b) busting the little connector attached to the base plate.
Just to be clear, I'm looking for this (and the connector that goes on the horn wire if you have it): I know these are available from AA, but I thought there might be surplus around. Thanks. |
mepstein |
Sep 15 2014, 12:14 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Pm me your address and I will send you the parts. $n/c
Mark |
BeatNavy |
Sep 15 2014, 12:19 PM
You are the man, sir. Thanks, Mark (and the community comes through again, in record time).
914Sixer |
Sep 15 2014, 03:24 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
New ones available at Sierra Madre Collection
bandjoey |
Sep 15 2014, 05:59 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
U can also Drill with small sheet metal screw the wire in place. Broke my tab off too.
BeatNavy |
Sep 15 2014, 06:36 PM
Mblizzard |
Sep 15 2014, 06:38 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
You can also use a Dremel to cut a new tab.
mepstein |
Sep 15 2014, 06:55 PM
Will mail in the am. The brown is just a little residue from the fiber washers. If you need any of the other small parts that go along with it, let me know before 9am tomorrow
Attached image(s) |
malcolm2 |
Sep 15 2014, 07:18 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
You can also use a Dremel to cut a new tab. What Mike said.... he suggested I do that about a year ago and it worked and so does the horn, nothing to it. Radio Shack will have the small width connector. Just crimp it on the wire after you pell back a bit of insulation. Auto parts stores might too. Clark |
BeatNavy |
Sep 15 2014, 07:38 PM
Will mail in the am. The brown is just a little residue from the fiber washers. If you need any of the other small parts that go along with it, let me know before 9am tomorrow Hi Mark - that's perfect, thanks! You can also use a Dremel to cut a new tab. What Mike said.... he suggested I do that about a year ago and it worked and so does the horn, nothing to it. Radio Shack will have the small width connector. Just crimp it on the wire after you pell back a bit of insulation. Auto parts stores might too. Clark Good suggestions as well. I should have considered that, but I lost both the connector and the tab. I think part of the problem is I THOUGHT that wire threaded through the circular hole in the horn plate, but I kept screwing up the wire when I tried to put the horn pad back on. I finally took the horn pad off my other project teener and it wasn't like that at all. Thanks for everyone's help. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:47 PM |
