> So my 914 tried to kill me the other day, need some advice
dcecc1968
post Nov 7 2014, 03:36 PM
So I'm driving my 914 home in Charlotte 5:00pm rush hour traffic (down Independence Blvd for you locals) and my rpms go up to 3000. I have had this happen before but was able to lift the accelerator pedal to unstick a cable to return to normal...not so this time. I stop in a parking lot because I'm convinced the cable is stuck and holding the carb open..... not so, the cable is fully retracted. Get back in the car, then the rpms go up to 4000, then 4500 and I'm having to drive the car by braking and feathering the clutch all the way home, about 15 miles. By the time I got home, a little smoke and I could smell the clutch. I have not started it since. FYI- I have a 1.7 L with a single carb (been told its a Weber) that I have had for about a year and I have no history on the car or carb.
Two questions:
1. Is it time for a carb. rebuild? How much does a kit run? Or time for a new carb.... or switch to new carb(s).?
2. Does this mean my clutch is spent?
Photo of carb.
Cap'n Krusty
post Nov 7 2014, 03:47 PM
Cap'n Krusty
The very first thing you should do is determine the ststus of the throttle plate. If it's not closing all the way, there's the fundamental issue. Disconnect the throttle cable at the throttle arm of the carburetor and see if that fixes it. If not, remove the air cleaner and take a look down the throttle bore. Something stuck in there? Choke stuck on? If removing the cable solves the problem, look at the pedal, the rod, the bell crank in the pedal cluster, and the front end of the cable. Disconnect it there and see if it moves freely. Report back.
The Cap'n
Mblizzard
post Nov 7 2014, 03:57 PM
Are you not missing a hose from the oil fill/PVC valve? Chech for vacuum leaks all around.
Clutches can take a good deal of abuse so unless you were extreme in riding the clutch it may be ok.
But overall if it is the carb, don't go back single.
914Sixer
post Nov 7 2014, 07:45 PM
Make sure your cable is not wrapped around any other cables in the tunnel.
post Nov 7 2014, 09:08 PM
double check the bell crank like Cappy said. A weak weld joint that can allow the cable to lodge against the tunnel wall. is your pedal stop adjusted properly? if not you may have bent it already!
EdwardBlume
post Nov 7 2014, 09:14 PM
High RPM is more air into the throttle assembly, either by wire, throttle open, plenum allowing air in, or a combination platter.
Ed_F
post Nov 8 2014, 10:41 AM
I had this happen to me with a type 1 1776 with dual Webers . Coming into LA on I5 during rush hour, the RPMs shot up to around 3500. I too thought the throttle cable was sticking as it was intermittent. I made it all the way back to Texas before realizing the right side intake runner nuts were about to fall off (IMG:style_emoticons/default/blink.gif) Check those runner boots for holes, and see if the runners loosened up at the heads.
Elliot Cannon
post Nov 8 2014, 12:00 PM
Group: Retired Members
Your car didn't try to kill you. What it did was remind you that it is very old and needs constant care. Kinda like Capn' Krusty. (IMG:style_emoticons/default/av-943.gif)
dcecc1968
post Nov 10 2014, 03:08 PM
Guys, thanks for all your posts... a wealth of wisdom. So I had some time this weekend and disconnected the cable from the carb via the bell housing and discovered the problem (see the photo below). The cable was "too short" to allow the throttle plate to close, thus the 4000 rpm. So I think maybe the recent cold weather shrunk the cable (so I thought). I adjusted threaded bell housing to extend the reach, reconnected it and viola, the throttle plate closed. Took it out for a test drive, within a few miles....4000 rpm again. Back to the garage, pull off the cable, same thing again too short...Hmmm am I in the Twilight zone, maybe I didn't extend it enough? No more threads left on the bell housing, so I fed some of the cable of the out bell housing so there was even a little slack, then re-attached. Drive to work this AM...... 4000 rpm again!
Oh yeah... I realized I don't even have pedal stop !
So, using the collective wisdom of the previous posts, this is probably not a carb issue, but a bent bell housing at the pedal end. Do I inspect this area by taking off the pedal board and is the bell housing at the pedal end the same as the one at the carb?
Can this be re-straightened or do I need to buy a new cable (PS - I know that my cable is frayed at the carb end).
Thanks in advance for your help.
-Don
Dr Evil
post Nov 10 2014, 09:00 PM
Send me your transmission!
Is it sliding in and out of the sheath easily? Likely binding up/splitting. That fray is a problem, too. It can catch on stuff and keep it from letting the cable release.
blabla914
post Nov 11 2014, 11:32 AM
I like primer
[/quote]
at some point soon you should consider replacing those boots that connect your plenum to the runners. They all looked pretty cracked. That will make a big vacuum leak and certainly not help the situation. Naturally this is after you fix your frayed throttle cable.
Kelly
cpavlenko
post Nov 11 2014, 11:43 AM
(IMG:style_emoticons/default/agree.gif) with dr.evil.
dcecc1968
post Nov 11 2014, 03:47 PM
Yes, the cable pulls freely in the sheath, when I disconnected it from the carb, I had my son press the accelerator and I was able to gently pull it back at the carb end.
What has me baffled is the "return point" of the cable seems to be changing. Everytime I adjust the cable so the throttle plate is closed, then drive it, the darn throttle plate end up "open" again to the same point that causes the 4000 rpm. That is why I wondered if I bent something each time I depressed the accelerator pedal (since I don't have a pedal stop).
r_towle
post Nov 11 2014, 04:01 PM
Custom Member
There is a piece of spring steel on the bottom of the gas pedal and is a big part of helping you have a cable return.
Pull the rod off the back of the gas pedal so it stands free of anything and see if when you push it down, it comes back up again on its own.
If not, you need a new one.
The piece of steel is molded into the pedal.
Yes, there are lots of wrong ways to do it, or you can buy a new pedal.
FourBlades
post Nov 11 2014, 07:42 PM
From Wreck to Rockin
If your ground strap on your transmission is worn out or dirty then your accelerator or clutch cables can be acting as your ground. Apparently, this makes them act funny.
Or at least I have heard the grey beards on here muttering about that...
John
ThePaintedMan
post Nov 11 2014, 08:13 PM
That cable is trash. I'm almost certain that the fraying is what is causing your problem. Do not cheap out on this one - it's your life and that of your passengers. Order a new $20.00 throttle cable from Pelican Parts. At least you can start there and we can check that one off the list of variables.
dcecc1968
post Nov 12 2014, 07:28 AM
Thanks guys. I do need to go ahead and check the ground strap and order a throttle cable. I'm thinking of possibly going dual carbs, so would I need a different cable set-up? Seems the same cable should work, but I wanted to check.
mgp4591
post Nov 12 2014, 12:30 PM
Does the throttle plate return smoothly without the cable attached? You could have some carbon buildup around the shaft that needs to be worked out with some carb cleaner and elbow grease. Make sure there's no stiction at all in that assembly.
dcecc1968
post Nov 12 2014, 03:10 PM
Yes, I used carb cleaner and sprayed the carb while running. As soon as I disconnect the cable from the carb, it returns to normal idle.
Now when the engine is off and I push down on the throttle plates manually, they do not return fully to closed position (see photo below), but as soon as I turn the throttle on the carb, the return to fully closed position. I just assumed I created a "choked" position with the carb when I manually pushed them down, but maybe this is a problem too?
Brian_Boss
post Nov 12 2014, 04:08 PM
I'm no expert on the Pinto carb but I'm pretty sure that's the choke not the throttle plates you pushed open and it's not relevant to your issue.
Sorry if this has already been answered but when it is doing the high idle, can you bring it down by pulling up on the pedal?
And, please get a new cable. The stock cable works fine with most carb linkages for duals.
- Lo-Fi Version Time is now: 1st May 2026 - 06:29 AM
