| gryphon68 |
Nov 11 2014, 09:42 AM
Member ![]() ![]() Group: Members Posts: 61 Joined: 2-October 13 From: SE Michigan Member No.: 16,462 Region Association: Upper MidWest |
Hi all,
Looking for some info I didn't see discussed in the other threads that mentioned MaxJax. For those that have the MaxJax installed, what spacing are you using for your 914. Spacing is typically measured from outside to outside of the floor plates. Also are the arms extended or retracted with the 914? What other vehicles have you had on the hoist without or without moving a column from the 914 position? Bonus points for other Porsche products . . . (Boxster?) |
| Rrrockhound |
Nov 11 2014, 06:11 PM
Member ![]() ![]() Group: Members Posts: 199 Joined: 30-November 05 From: Delaware, OH Member No.: 5,213 Region Association: None
Hi all, Looking for some info I didn't see discussed in the other threads that mentioned MaxJax. For those that have the MaxJax installed, what spacing are you using for your 914. Spacing is typically measured from outside to outside of the floor plates. Also are the arms extended or retracted with the 914? What other vehicles have you had on the hoist without or without moving a column from the 914 position? Bonus points for other Porsche products . . . (Boxster?) I've used my MaxJax with my teener, my 996 and 911SC, BMWs (E30, E46, E34 and E39), my Miata, a Lincoln MKX and even my F-150. The only time I ever moved the columns was when I bought a new house, when I re-spaced them a little farther apart. Spacing isn't real critical since the arms are easily adjustable. You also don't necessarily use the same arm adjustment every time since it's tough to get the car exactly centered between the columns. It's dark and raining out right now but I can go out to the workshop and measure the spacing for you tomorrow. |
| doug_b_928 |
Nov 12 2014, 09:41 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 730 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I place my posts at, I think, either 129 or 130 inches (cf. the owner's manual for the maximum allowable). That works great for the 914. The most difficult vehicle to fit on mine thus far is a Cayenne. It works great but the car has to be placed perfectly to reach the jack points (because they are inset from the edge of the chassis and they are farther apart front to back due to the size of the vehicle).
| doug_b_928 |
Nov 12 2014, 09:47 AM
Just remembered, max is 130" but I had to put mine at 129" for the Cayenne.
| gryphon68 |
Nov 12 2014, 10:56 AM
Thanks for the replies, I don't think 130" is a maximum in the sense of safe operation, I think they are just saying that typically you would never put anything on a 6000# lift that was wide enough to require more than 130" spacing.
I was looking at 125" as a starting point for my install. Not sure what that would preclude me from fitting on the lift as well as wanting to make sure that would still accommodate the 914. |
| Phoenix-MN |
Nov 12 2014, 11:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
I spaced mine at 125" works for my 914, 911, and Scion Xb, I also have a Grand Cherokee and Dakota Quad Cab but have not used it with those two
Here's how I position the cars ![]() |
Lo-Fi Version | Time is now: 6th June 2026 - 08:20 AM |
