| OU8AVW |
Nov 20 2014, 09:31 PM
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,806 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
I have an early car (1971) with a late side shift and motor combo. I have stock "soft mounts" for the engine to bar connection. My car has original style soft mounts on the body. Looks like I should have solid mounts in one of these spots. Any recommendations? I am inclined to swap out the mounts for the bar to body connection as I am missing a few parts off these. Maybe Renline or semi-rigid WEVO mounts......
Solid Motor to bar mounts sure are cheaper. I have stock 911 motor mounts for my transmission. Thanks! |
| 914werke |
Nov 20 2014, 10:12 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,726 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
The early car setup had rigid mounts at the motor & flex mounts at the chassis (ends of the eng. mount bar).
Just so happens that the early mounts at the chassis point are the same as the trans mounts for all cars. For later cars with side shifter that config was switched with flex mounts at the engine and solid mounts at the chassis (ends of the late eng. mount bar) If you still have flexible mounts at both points yes you need the late bar end chassis mounts. Attached thumbnail(s) Attached image(s)
| bdstone914 |
Nov 20 2014, 10:29 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,351 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If you have flex mounts at the end of the chances are that the bar was modified to work with them. Otherwise the bar would sit too low and interfere with the shift rod.
| 914werke |
Nov 20 2014, 10:43 PM
Good point. Mike you say you have a late side shifter setup does that include the late Eng. bar? Ive seen some crazy stuff made to work.
As an example Check this out |
| OU8AVW |
Nov 21 2014, 06:13 AM
I have a late bar. The transmission and side shift set up are new to the car and have never been installed/run. That's part of the issue. Seems like going with a 100% late set up is the way to go.
With that said, sounds like I'm in the market for a set of mounts to attach the bar to the body. Engine to bar is all squared away. |
| OU8AVW |
Nov 21 2014, 06:17 AM
This is what I have.
This is what I need? |
| mepstein |
Nov 21 2014, 07:03 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,859 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Mike. If I still have them from my old car, you are welcome to them. I won't have a chance to dig through the boxes until sat afternoon but I'll let you know. Mark
| OU8AVW |
Nov 21 2014, 09:18 AM
| bdstone914 |
Nov 21 2014, 09:31 AM
Mike
You have what you need to mount the bar to the body. There are no mounts used at the end of the bar. If you need the rubber mounts that attach to the engine mounts and bar buy them new. Used ones get wedge shaped. |
Lo-Fi Version | Time is now: 11th August 2026 - 04:21 PM |
