| MJHanna |
Dec 11 2014, 08:47 PM
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
looking for ideas. Mine is cut but it not large enough to be useful. So I'm going to enlarge it and would like to see others solutions.
| SirAndy |
Dec 11 2014, 08:49 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,519 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I know it's kinda tight in there, but i really don't think it's needed at all.
I replaced the alternator, engine harness and belt on my 3.6L and it wasn't that hard to do. (IMG:style_emoticons/default/shades.gif) |
| GeorgeRud |
Dec 11 2014, 10:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I think that perhaps just getting a larger cut piece of the firewall from another parts car would allow you to overlap a cutout and fasten it with Dzus fasteners. The thickness of the overlapping areas should be inconsequential.
| Krieger |
Dec 11 2014, 10:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,879 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
I made a cardboard template to cover the opening I made. About 3/4" bigger all around than the opening in firewall. I traced it onto a sheet of aluminum and cut out with my jig saw. I used a rubber mallet to shape it on the fire wall. I tack welded 8 small nuts on the engine compartment side to make for easy removal/install.
| Krieger |
Dec 11 2014, 10:31 PM
From the F-914 build in my signature.
| mepstein |
Dec 12 2014, 06:12 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,918 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
i have a large piece of firewall. pm me if interested. include your email so i can send pics. mark
| EdwardBlume |
Dec 12 2014, 06:40 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I installed a zipper and sprayed it with rust. (IMG:style_emoticons/default/lol-2.gif)
The last race car had a similar opening like Krieger's. Sheet of aluminum covering it with screws holding it in. Never needed to use it though. |
| t collins |
Dec 12 2014, 07:10 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,271 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
After cutting the opening, I spot welded an 1/8" thick reinforcing ring and then drilled/tapped for the cover screws
| Cairo94507 |
Dec 12 2014, 08:08 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,767 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Scotty and I were just discussing this for my Six. I really do not want to cut a hole in the firewall but I do acknowledge that access would make life easier if I need to replace a belt or alternator. What is the general consensus here? I am leaning towards no hole, but could be swayed..... Although Andy's post gives me hope this can be avoided. (IMG:style_emoticons/default/w00t.gif)
| ChrisFoley |
Dec 12 2014, 08:13 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,032 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
No hole.
| naro914 |
Dec 12 2014, 08:15 AM
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Not easy to see, but we just did a very clean/straight cut out, made an aluminum 'door' just a bit bigger, and used hinges on the bottom and 1 dzeus fastener on top. Very simple. this way there are no screws or nuts to deal with that might get dropped or lost when you open it up. Painted it when I painted the interior.
| mepstein |
Dec 12 2014, 08:37 AM
Scotty and I were just discussing this for my Six. I really do not want to cut a hole in the firewall but I do acknowledge that access would make life easier if I need to replace a belt or alternator. What is the general consensus here? I am leaning towards no hole, but could be swayed..... Although Andy's post gives me hope this can be avoided. (IMG:style_emoticons/default/w00t.gif) Not in an orig 6. Bend a wrench to fit around the fan and keep in in the car. There was a thread on this about a month ago. Actually, have scatty make 2 since I want one. (IMG:style_emoticons/default/biggrin.gif) |
| pcar916 |
Dec 12 2014, 09:02 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
I vote for easy access in the dark on a lonely road in the mountains, or on the track between runs. What's likely to happen? Perhaps a broken or compromised fan belt. Mine gets inspected and replaced fairly often so it's never happened to me, but it did when I had the PO installed 2.7L. Not an enjoyable operation. My thinking on the size?
I choose not to give myself cramps trying to do two-handed operations through a small hole. This access hole lets me do anything I need to do, including getting the spanner onto those 3.6L pulley holes and fussing with the shims on the fan pulley. The metal is thin enough to snake out from behind the cage-crossmember, thick enough to still be a firewall, and with the Dzus fittings, is easy to remove/install. The only thing I have to do is remove the passenger seat, a 5-minute thing. When on the road, I carry a huge plastic bag to cover it if it's raining. ![]() ![]() ![]() |
| Mark Henry |
Dec 12 2014, 09:16 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
For those that don't put a hatch in how do you time the engine?
Is FI a pre set and forget? And Andy how did you get the alt out? Do you have a 2 piece shroud? My engine is a twin plug/MSD with webers I have no idea how to time it easy without a hatch (IMG:style_emoticons/default/confused24.gif) |
| fixer34 |
Dec 12 2014, 09:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,471 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
My one and only experience with replacing a fan belt on a /6 with the engine in the car was at night, on a Texas freeway, 1000 miles from home. I had only owned the car less than a year. Luckily, it had the full toolkit and a spare belt. After waiting a while for the engine to cool down, I was able to replace the belt with just the factory supplied tools. Not easy, but doable. I would think it would more hassle removing the seats and back pad to get to an access panel than just doing it the 'right' way. And how often do you need to change a belt anyway?
Regarding the timing, on a factory six, the timing marks are on the flywheel and there is an access hole in the case. Very easy to put a timing light to; just a little unnerving adjusting the distributor to full advance at 6000 rpm. |
| pcar916 |
Dec 12 2014, 10:22 AM
On my 2.7, also MSD, I timed on the flywheel with a degree-dial type light. Ahead of Andy's answer, the DME is 100% computer controlled and the distributors are fixed. The 3.6 has a two-piece shroud which makes the alternator job easier.
Interestingly, I discovered when Andy told me there was a factory recall on 993 engine wiring-harnesses, my large access hole allowed me to tilt the fan forward without disturbing the fanbelt pulley. Saved a fair amount of time, but effects only 993 and perhaps 964-engine 914's. |
| SLITS |
Dec 12 2014, 10:30 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
My one and only experience with replacing a fan belt on a /6 with the engine in the car was at night, on a Texas freeway, 1000 miles from home. I had only owned the car less than a year. Luckily, it had the full toolkit and a spare belt. After waiting a while for the engine to cool down, I was able to replace the belt with just the factory supplied tools. Not easy, but doable. I would think it would more hassle removing the seats and back pad to get to an access panel than just doing it the 'right' way. And how often do you need to change a belt anyway? Regarding the timing, on a factory six, the timing marks are on the flywheel and there is an access hole in the case. Very easy to put a timing light to; just a little unnerving adjusting the distributor to full advance at 6000 rpm. I have the hatch and I have the hole in the tin for timing. It's hell to be standing, shooting the light at the hole and marks on the flywheel and then trying to turn the dizzy. Also, when fitting the early flywheel to a 2.7L at least, the marks on the flywheel are way off. I use the hatch ... pull the seats and backpad ... easy peasy ... remembering Moab 2014 .... (IMG:style_emoticons/default/sad.gif) I will be adding the Electromotive HPV-1 system next ... worst part is getting the sensor lined up with the 11th tooth ... after that timing is not a problem. |
| pcar916 |
Dec 12 2014, 10:33 AM
I would think it would more hassle removing the seats and back pad to get to an access panel than just doing it the 'right' way. (IMG:style_emoticons/default/agree.gif) and would have the same opinion if my firewall wasn't exposed. |
| brant |
Dec 12 2014, 10:47 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,277 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I use mine all of the time...
in fact I used it again last weekend, and practically open it every single post-race but its a race car I wouldn't do it on a street car Attached image(s)
| Mark Henry |
Dec 12 2014, 10:52 AM
I just pulled my seats and pad, I didn't think it was a big deal. I wouldn't pull them for just a belt.
Still thinking on this, high compression twinplug, I don't want to be fuching around with the timing too much the wrong way. (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 22nd September 2026 - 05:07 AM |
