| mepstein |
Dec 12 2014, 04:17 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,545 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The only thing I know about suby transmissions is that I want one for my eg33 conversion. What model should I buy? What should I expect to pay, Where should I look? Blah, blah, blah.
Thanks in advance! |
| mgp4591 |
Dec 12 2014, 04:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
I'm using an automatic, but then I'm kinda strange... (IMG:style_emoticons/default/blink.gif)
| JRust |
Dec 12 2014, 04:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
I believe you are going to want an 02-04 WRX tranny. It can handle the torque of the eg33. A stock forester or outback tranny from a 4 cylinder won't cut it. Axle wise there are some difference's. Also I think a 97-98 out of an RS can handle it too. An STI 6 speed would be sweet but I think there is maybe a 2 year window there that would work. Sorry I don't know this all that well. This is what I've gleaned from reading up & talking with my buddy Ian at Coldwater.
| mepstein |
Dec 12 2014, 04:59 PM
I believe you are going to want an 02-04 WRX tranny. It can handle the torque of the eg33. A stock forester or outback tranny from a 4 cylinder won't cut it. Axle wise there are some difference's. Also I think a 97-98 out of an RS can handle it too. An STI 6 speed would be sweet but I think there is maybe a 2 year window there that would work. Sorry I don't know this all that well. This is what I've gleaned from reading up & talking with my buddy Ian at Coldwater. I plan to use just about everything he sells so I'll give him a pm to see what he might already have in stock. thanks |
| 76-914 |
Dec 12 2014, 06:16 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Read thru Chris and my build threads. That's all covered including clutch info.
| mepstein |
Dec 12 2014, 06:20 PM
| returf |
Dec 12 2014, 06:23 PM
Member ![]() ![]() Group: Members Posts: 67 Joined: 15-August 12 From: New Zealand Member No.: 14,806 Region Association: Australia and New Zealand |
If you're going to develop the engine later on, I would go for the sti six speed. I've seen too many broken standard five speeds.
| mepstein |
Dec 12 2014, 06:39 PM
| 76-914 |
Dec 12 2014, 08:32 PM
Read thru Chris and my build threads. That's all covered including clutch info. will do - who is chris Chris H. on here. He is the guy that responded to your earlier Suby post. Good guy and has done the EG33 conversion. Outside of our engine choice, tranny, and hydraulic clutch, we approached the conversions from different angles. I think you should look over every ones Suby build, augment and improve our methods for the next builder. When you have that tranny on the bench listen when shifting thru the gears. Reverse makes a distinctly different sound. You'll hear it. Helps in figuring out the shift pattern. Someone posted a Suby index............Britton ????? Sheez, I forget but it's bookmarked if you need it. Although there are a few more builds since that was started there is some very good info there. Enjoy the Challenge. (IMG:style_emoticons/default/beerchug.gif) |
| rnellums |
Dec 12 2014, 09:04 PM
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,673 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Pick the newest one you can find with the tallest gears. I've got an 03 2.5 RS mated to my 3.0-6 and while the acceleration in 2nd and 3rd is great, revs are pretty high on the highway for cruising.
| a914622 |
Dec 13 2014, 10:03 AM
Member ![]() ![]() Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
I am going with the late model cable shift 6 speed. 2010 gt and up as well as a few spec B . In 12 all the 6 speed are cable shift. Much improved tranny redesigned with wider gears and able to handle the 300 tork of the Diesel engines.
Search auto-parts dot com. They run 1500-2000. The sti trannys are bigger. Long,tall, and all the rage for the wrx guys that keep braking the 5 speeds trying to do a 4wheel burn out. So 3-4k and I'm not sure it will fit? If your looking at the 5 speeds on the cheap almost any of the hyd clutch ones will work. Remember the 914 drops almost 1000 lbs off a wrx and with the tranny only 2wd I think the tires are going to go before the tranny. The 5 speeds are unbalivably simple to rebuild. The bearing press it the only pain in the ass. You want to match the clutch with the flywheel. Wrx is the same as the 911 and needs the pull style arm and slave cylinder. Good luck. Jcl |
Lo-Fi Version | Time is now: 17th March 2026 - 09:49 PM |
