NPC: pocket door hardware needed!, anybody have this type pf hook? |
ripper911 |
Dec 29 2014, 02:20 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
The new guy at work broke the embalming room door. It's a pocket door, and it looks like the hooks ate no longer available.
Does anybody have one of these screw in hooks sitting around that they can send me? (IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1419884435.1.png) |
r_towle |
Dec 29 2014, 02:57 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
no, sorry.
You can however buy a whole new set of hardware for pocket doors at any decent lumber yard. Its a standard Brosco Item. rich |
ripper911 |
Dec 29 2014, 03:02 PM
One of my fellow directors is gone to the door surplus store to see if they have one... With the type of door we have it looks like we can't even get the rollers out without taking out the frame.
We've been trying to rig it up for half of the day. |
r_towle |
Dec 29 2014, 03:12 PM
One of my fellow directors is gone to the door surplus store to see if they have one... With the type of door we have it looks like we can't even get the rollers out without taking out the frame. We've been trying to rig it up for half of the day. you can and you cant....pocket doors are tricky to work on, but if you look at the extension jambs, you can remove those without taking off the outer trim.... if you must, slip a hand held hacksaw blade between the trim and the jamb and slide it down to find all the nails, then cut them off. The jamb will pull out towards the middle of the opening, so you should not need to touch the outer trim. Once the jams are removed, the whole hardware setup will come out. Typically you can remove just one side, and if you look close, one side it typically fastened less than the other.... If you remove one side, you can swing the door into the room in that direction and remove the rollers.... Its funky spacial geometry, but there is a trick to every door and how to remove it. Worst thing is they nailed through the trim into the jam. Then use the blade to cut those nails. When you put it back together, use screws to screw in the jam, nothing more. rich |
r_towle |
Dec 29 2014, 03:14 PM
think of it this way.
The overall opening fit the door when they put it in. After the door was put in place, the jambs made the opening smaller. Remove the jambs, remove the door. Leaving the trim on the outside is the tricky part so you wont need to repair any of that. |
ripper911 |
Dec 29 2014, 04:12 PM
I'll keep that in mind if we can't find an easy replacement piece.
I'm thinking about finding a screw with the right thread and adapting it to hold the door. But, I'm home and off call! It's time for a drink! (IMG:style_emoticons/default/bootyshake.gif) |
r_towle |
Dec 29 2014, 04:23 PM
I'll keep that in mind if we can't find an easy replacement piece. I'm thinking about finding a screw with the right thread and adapting it to hold the door. But, I'm home and off call! It's time for a drink! (IMG:style_emoticons/default/bootyshake.gif) take the two pieces to a welder and have them put it back together.... rich |
Lo-Fi Version | Time is now: 1st June 2024 - 08:55 PM |
