Eye Lid Grommets, What is the secret to installing them? |
74914LE |
Jan 17 2015, 12:21 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
Anyone have a good process for installing the grommets for the headlight Eye Lids?
Thanks! Ford |
Bleyseng |
Jan 17 2015, 12:26 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Take a small flat screwdriver and push them in all the way till they seat
mepstein |
Jan 17 2015, 12:27 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
and use some lube on the rubber
Mikey914 |
Jan 17 2015, 01:57 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Make them from silicone and a bit softer than OEM so they slide in a little easier.
Mind you they are still a tight fit, but soapy water will help both types |
injunmort |
Jan 17 2015, 02:44 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
dawn dishwashing detergent on the nipple, I wrap a piece of wire around the groove, pull the wire thru the hole and pull it into place then unwrap the wire. makes life easy
KELTY360 |
Jan 17 2015, 02:47 PM
914 Neferati Group: Members Posts: 5,035 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
and use some lube on the rubber I know this always works for me. (IMG:style_emoticons/default/shades.gif) |
Mikey914 |
Jan 17 2015, 02:48 PM
PanelBilly |
Jan 17 2015, 02:53 PM
914 Guru Group: Members Posts: 5,811 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Get you some sex lube. It's the perfect excuse to buy some. Tell the girl behind the counter, you're using in to help slide the rubber plug in!
TJB/914 |
Jan 17 2015, 03:07 PM
Mid-Engn. Group: Members Posts: 4,334 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
and use some lube on the rubber (IMG:style_emoticons/default/agree.gif) Here's another tip. I have a very thin wire hooked to the front hood latch threaded under the headlight eye lid that is difficult to see. It's there in event the pull cable/handle breaks inside the car and you cant open the hood. Mine has a little carved (yellow) pull handle scale 914 model you will never see unless you take the headlight eye lid off. (IMG:style_emoticons/default/happy11.gif) This photo might not show the details???? Tom Attached image(s) |
TJB/914 |
Jan 17 2015, 03:17 PM
and use some lube on the rubber (IMG:style_emoticons/default/agree.gif) Here's another tip. I have a very thin wire hooked to the front hood latch threaded under the headlight eye lid that is difficult to see. It's there in event the pull cable/handle breaks inside the car and you cant open the hood. Mine has a little carved (yellow) pull handle scale 914 model you will never see unless you take the headlight eye lid off. (IMG:style_emoticons/default/happy11.gif) This photo might not show the details???? Tom Better picture (IMG:style_emoticons/default/drooley.gif) Save yourself when the hood cable breaks. Tom Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:47 AM |
