Very Stupid Question Mounting engine to transmission- Gasket? |
stevefed |
Feb 15 2015, 07:12 PM
Newbie Group: Members Posts: 4 Joined: 2-November 14 From: CA Member No.: 18,082 Region Association: Northern California |
OK, I've looked at all parts schematics I could find, and for the life of me I can't find any mention of, or view of, a gasket that goes between the 901 transmission where it mounts to the engine. This is an electric engine I am mounting, but it should be the same, as it has an adapter plate that matches just the same. Neither the engine rebuild gasket kits, or the transmission kit that I bought (or any other kits) show, list or explain the use of any gasket when mounting the engine and trans together. Both the Haynes and EV conversion manual simply say to "bolt them together." Since I"m kind of anxious to get going on this, does anyone have an answer to this incredibly stupid question?
r_towle |
Feb 15 2015, 07:14 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
No gasket
Java2570 |
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
No gasket between the trans and engine, they just bolt together.
stevefed |
Feb 15 2015, 07:19 PM
Well alright then! Thanks for getting back to me. I guess it's time to get busy.
r_towle |
Feb 15 2015, 07:34 PM
Please post a build thread with all the details of the controller, the batteries, the distance,
I want to do this to a beetle.... |
Mikey914 |
Feb 16 2015, 02:55 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The ground wire is on the trans so the gasket would hinder the current, probably through your clutch cable as that's the next shortest path.
Lo-Fi Version | Time is now: 28th May 2024 - 11:36 PM |
