Headlight wiring, Is this correct? |
Doug Leggins |
Feb 7 2005, 08:43 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I have lost a few pics that I had for reference.
Can someone confirm that the yellow, brown and white wires are hooked up correctly? And, that the drivers side and passenger side should be wired the same? Attached image(s) |
Gint |
Feb 7 2005, 09:02 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Doug Leggins |
Feb 7 2005, 09:29 PM
Thanks Gint!
Both sides the same? Seems to me that they would have to be wired the same since a replacement headlight can be installed on either side of the car. But....just want to be sure. |
Gint |
Feb 7 2005, 09:32 PM
Both sides are the same.
Keeps those pics and resto tips coming Doug! I'm gonna need 'em. I can't say enough about the quality of you're work. Beautiful. I'll certainly help you where I can. |
Doug Leggins |
Feb 7 2005, 09:55 PM
Thanks again Gint!
I was pretty sure that the wiring was correct. But after taking the driver's headlight assembly back out/apart to make room for adjusting the body lines, thought that I'd be certain that the wiring was correct. |
Lo-Fi Version | Time is now: 29th May 2024 - 05:51 AM |
