| PanelBilly |
Mar 4 2015, 12:47 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,950 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
| Mike D. |
Mar 4 2015, 12:53 AM
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,457 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None
It connects via an "expensive" hose to your oil tank; there is a connection pipe next to the fill spout.
| PanelBilly |
Mar 4 2015, 12:59 AM
| Downunderman |
Mar 4 2015, 03:05 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
You will find that if you just put hose on it and secure it with a hose clamp it will leak and drive you crazy because when the hose clamp is tightened it will distort the pot metal spout.
Its best to machine up an aluminium extension and glue to the spout with high temp epoxy and connect the hose to that. Cheers, |
| Luke M |
Mar 4 2015, 08:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,497 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
The engine vents to the oil tank then there's another hose that comes off the filler neck that goes to the factory air cleaner (circled in red). If you are not using the factory air cleaner then you need to vent it to an aftermarket breather tank.
I posted pics of my factory 6 oil line arrangement. Yes, the fabric line is not cheap. Attached image(s)
| MJHanna |
Mar 4 2015, 08:19 AM
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
You can run it to a catch can/breather also.
| JmuRiz |
Mar 4 2015, 08:59 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
The engine vents to the oil tank then there's another hose that comes off the filler neck that goes to the factory air cleaner (circled in red). If you are not using the factory air cleaner then you need to vent it to an aftermarket breather tank. I posted pics of my factory 6 oil line arrangement. Yes, the fabric line is not cheap. So the line that comes off the oil tank filler neck is the one that goes to the airbox? I want to make sure I have mine setup correctly...not that it'll be done anytime soon. |
| screenguy914 |
Mar 4 2015, 11:33 AM
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
You can run it to a catch can/breather also. Yes. A catch can between the oil filler line and engine intake is suggested. Some attempt a catch can directly from the engine, but oil velocity is highest here and a catch can will fill much faster. The oil tank is a better transition path. Do not attempt to seal this path as some have tried. Crankcase blowby must be vented otherwise oil leaks will develop. After the catch can, some vent to atmosphere via a small, filtered breather cap, but suggest gas fumes recirculate back to the intake. Early 911 engines are dirty enough through the exhaust. No need to donate add'l unburned gas fumes to the atmosphere. Sherwood |
| SirAndy |
Mar 4 2015, 11:43 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The case vent goes straight to the oil tank:
(IMG:http://www.914world.com/bbs2/uploads/post-179-1202450158_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1202450792_thumb.jpg) The filler neck vent goes to the air filter or a catch can, depending on your intake system. (IMG:http://www.914world.com/bbs2/uploads/post-179-1255294222.jpg) (IMG:style_emoticons/default/piratenanner.gif) |
| '73-914kid |
Mar 4 2015, 02:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
You will find that if you just put hose on it and secure it with a hose clamp it will leak and drive you crazy because when the hose clamp is tightened it will distort the pot metal spout. Its best to machine up an aluminium extension and glue to the spout with high temp epoxy and connect the hose to that. Cheers, (IMG:style_emoticons/default/beerchug.gif) Ive been fighting an oil leak at the hose for a year now, been through different hose material, different hose clamps, even put some dirko on the hose.. and the damn thing refuses to seal. This sounds easy enough to make. |
| patssle |
Mar 4 2015, 02:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
You can get colored heater hose cheap on ebay. This is what I'm using engine to oil tank. Then tank into a Gatorade bottle like Andy.
http://www.ebay.com/itm/HEATER-HOSE-1-ID-R...=item2ede5cf6e0 |
| SirAndy |
Mar 4 2015, 04:45 PM
You can get colored heater hose cheap on ebay. Just make sure that whatever you're using is oil resistant ... (IMG:style_emoticons/default/shades.gif) |
| PanelBilly |
Mar 4 2015, 04:49 PM
| jd74914 |
Mar 4 2015, 05:14 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Yes, I would run it to the intake or a catch can. With just a filter there you might get oil on everything.
| johnhora |
Mar 4 2015, 05:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 902 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
| Jeffs9146 |
Mar 4 2015, 06:44 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Here is mine! (IMG:style_emoticons/default/shades.gif)
Attached thumbnail(s) |
| patssle |
Mar 4 2015, 07:13 PM
You can get colored heater hose cheap on ebay. Just make sure that whatever you're using is oil resistant ... (IMG:style_emoticons/default/shades.gif) Interesting - what will oil do....seep through or eat away at it? |
| t collins |
Mar 4 2015, 07:48 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
I wouldn't say it's the best way but has worked well for me so far
| rgalla9146 |
Mar 4 2015, 09:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Leakage at the breather nipple on the engine should not be a problem.
Start with a new hose. And a narrow hose clamp, not a big beefy thing from a radiator hose. Push the hose fully onto the nipple till it bottoms. Install the hose clamp at the end of the hose, but..... fully on the hose. The clamp must be below the steel ball that is cast into the nipple. See attached photo. Leakage comes from old hard hose that has had the clamp incorrectly tightened on top of the ball. The nipple should have had a conventional rim rather than the troublesome ball. Attached thumbnail(s) |
| SirAndy |
Mar 4 2015, 10:22 PM
You can get colored heater hose cheap on ebay. Just make sure that whatever you're using is oil resistant ... (IMG:style_emoticons/default/shades.gif) Interesting - what will oil do....seep through or eat away at it? If the hose material is not oil resistant, it can break down and you end up with contaminant in your oil. Not good ... (IMG:style_emoticons/default/shades.gif) Also, with regards to the catch can, i drilled a few vent holes in the top of my bottle so vapors can escape. Which is also the reason why i placed it right next to the air filter. The holes point straight towards the intake filter and any vapors will be sucked in and burnt. I usually clean out the catch can every other month or so, it does collect some sludge on the bottom over time. (IMG:style_emoticons/default/FERG.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:14 PM |
