Tuna Can install, Unclear on installation |
LotusJoe |
Mar 10 2015, 12:11 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Porschef |
Mar 10 2015, 03:17 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/idea.gif)
I've got one he same and have been wondering too... |
Kansas 914 |
Mar 10 2015, 03:44 PM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
Is this from the Racer Chris - Tangerine group buy?
If so there are a lot of comments here: http://www.914world.com/bbs2/index.php?sho...236&hl=tuna can&st=200 |
DRPHIL914 |
Mar 10 2015, 08:20 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I'm in the process of installing the tuna can and am unsure what goes where. Any help is greatly appreciated. I just did this about 6 weeks ago. the strainer goes on the bottom facing upward. the bottom cover goes under that. you will need 3 seals. 1. bottom cover facing up, 2. put seal on this between it and the strainer, and 3. put another seal between the strainer and the tuna can 4 put seal on top of tuna can and attach to car. I don't remember which way the part you were asking about goes, but it will only fit one way. I think the longer part goes down, the shorter up, on top of the strainer. Some choose to use gasket sealer on the seals, I just put oil on them, I have not had a leak since I installed mine. Good Luck. Phil |
DRPHIL914 |
Mar 10 2015, 08:22 PM
Is this from the Racer Chris - Tangerine group buy? If so there are a lot of comments here: http://www.914world.com/bbs2/index.php?sho...236&hl=tuna can&st=200 that is from the guy in the U.K. got mine from the same place. He also has a nice billet taco plate for the oil temp sensor. I did both |
Valy |
Mar 10 2015, 09:42 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Whatever you do, make sure that the pickup tube extender is sealed around the pickup tube, else the engine will pickup air through the gap that will be higher than the original pickup tube. Kind of defeats it's purpose without sealant.
LotusJoe |
Mar 11 2015, 12:21 PM
I'm in the process of installing the tuna can and am unsure what goes where. Any help is greatly appreciated. I just did this about 6 weeks ago. the strainer goes on the bottom facing upward. the bottom cover goes under that. you will need 3 seals. 1. bottom cover facing up, 2. put seal on this between it and the strainer, and 3. put another seal between the strainer and the tuna can 4 put seal on top of tuna can and attach to car. I don't remember which way the part you were asking about goes, but it will only fit one way. I think the longer part goes down, the shorter up, on top of the strainer. Some choose to use gasket sealer on the seals, I just put oil on them, I have not had a leak since I installed mine. Good Luck. Phil Thanks Phil, How did you get the long bolt to go thru the strainer? |
ThePaintedMan |
Mar 11 2015, 12:24 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
DRPHIL914 |
Mar 11 2015, 12:39 PM
Thanks Phil, How did you get the long bolt to go thru the strainer? Just hog it out a little bit and make sure there are no shavings left in or around the screen. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 12:15 AM |
