High beams not working |
Larmo63 |
Mar 16 2015, 11:15 AM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Fuses are all in right, no action on stalk when I pull it. I did some dash work and now they don't work. Any suggestions?
Bruce Hinds |
Mar 16 2015, 11:21 AM
V-8 madness Group: Members Posts: 734 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
What dash work did you do?
Larmo63 |
Mar 16 2015, 11:31 AM
Dash top, gauge panel, everything out and disconnected.
Cuda911 |
Mar 16 2015, 12:00 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Relay on the back of the fuse panel maybe?
Dave_Darling |
Mar 16 2015, 09:19 PM
914 Idiot Group: Members Posts: 15,047 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
You pull the stalk, you don't hear a click and the low beams stay on?
The stalk isn't plugged in correctly, or you borked the microswitch when you had everything apart. --DD |
forrestkhaag |
Mar 17 2015, 10:45 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
You pull the stalk, you don't hear a click and the low beams stay on? The stalk isn't plugged in correctly, or you borked the microswitch when you had everything apart. --DD it may have happened when he used a snap-blade knife to remove the goo from the lower windshield edge while replacing his dash top thereby cracking his windshield (and blaming it on his pal ((me)) then, in a fit of uncontrolled slashing probably sliced thru the wiring harness below the dash... somehow...... See Page 01-2/9 ELECTRICAL WIRING DIAGRAM (PART II) Type 914, Model 72 - USA DUH |
76-914 |
Mar 21 2015, 09:38 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,608 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Did you get it fixed?
Jeff Hail |
Mar 21 2015, 01:30 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Lo-Fi Version | Time is now: 20th September 2024 - 06:22 PM |
