stuartgto |
Newbie ![]() Group: Members Posts: 15 Joined: 17-April 13 From: 94070 Member No.: 15,777 Region Association: None ![]() |
I would like to know if anyone has tried to install an electronic ignition for a 1970 914/6? Such as Pertronix? I or II? Or what else is out there? I want to keep it looking original, but have heard the reliability of the Pertronix can be an issue. Is it worth getting a new coil as well? Any thoughts and/or experiences are appreciated.
Also I am looking for a "readable" 1970 914/6 electrical schematic. Any hints? Thanks |
Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
If you're not worried about originality I'd go with the Electromotive Crankfire kit. It eliminates the distributor all together & once set stays spot on time providing great ignition & solid reliability. Please ignore my filthy carbs, they're next on my list. (IMG:style_emoticons/default/dry.gif)
Attached thumbnail(s) ![]() |
screenguy914 |
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California ![]() |
While crankfire ignition is quite accurate, I don't think most folks need to go to that extent to eliminate the variations inherent in breaker point ignition.
Besides Pertronix, Crane also offers a pointless module that fits in most Bosch distributors. Optional ignition coils are .... optional. 914-6 engines are the same as 1969 911T engines. Look for wiring diagram SL33 from the 911 repair manual and/or from a 914-6 manual (pretty sure it's the same). Try this source for factory info: http://early911nzdownloads.yolasite.com/workshop-manuals.php I have some early high res. electrical diagrams on my now-vintage website: http://members.rennlist.org/911pcars/ Sherwood |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,935 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
The 914-6 already has electronic ignition, except for the points that are still
mechanical and will wear over time changing timing. Pertronix does exist for the bosch distributor. A long time ago pertronix didn't make one for the Marelli distributor, but I don't know if that has changed. If you are worried about pertronix failing you, then just use good bosch distributor grease on the points rubbing block, and every off season just put in new points, they're cheap. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
The simplest method would be to leave the points and install a MSD....sounds weird right?
I'd install a new set of points, remove the condenser and just use them to trigger the MSD, no high voltage goes through the points so they never wear out. If you make a bracket the MSD can be mounted where the factory CD was or in a /6 conversion were the FI was mounted, it's quite a stealth install. Do not use too much grease, the low voltage will not burn grease off if it gets on the points. You may have to adjust the points lets say every 50K miles. BTW I haven't tried this on a /6, this is how I run a red top Mallory dual point dizzy for the T1 and T4, which is the exact same dizzy as the Unilite. These dizzy's can often be found for about $100 I removed the 2nd set of points and condenser. I've done this for several engines, works flawless. I have made the MSD bracket mentioned above for my /6 |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The Six already has a CDI, which is the same as an MSD except for the multiple-spark thing. Unfortunately, the points do wear mechanically--just not nearly as quickly as ones that carry lots of current.
Even more unfortunately, most or all of the original Sixes used the Marelli distributor. There is no points-conversion available for that unit that I know of. Crane did make a prototype for it, but they concluded that there wasn't enough market and never produced them. Someone around here did get ahold of the prototype, and said that it worked well. But I don't know what the differences are from a more standard Crane unit. You might be able to talk someone into making bits to adapt a Pertronix II or Compufire or Crane optical gizmo into your distributor. If they do, they'll probably be able to sell a few of them. But it'll be pretty much custom work, so it won't be cheap. If you're willing to hand your distributor over to someone for a while, it might be worthwhile. Marelli points were NLA new for a good while; not sure if they are now or not. If they are still NLA, then the market for a points-replacement gets a bit bigger... --DD |
Mark Henry |
MSD and points doesn't seem to wear very much, but that is on a T4 and a Mallory.
I've mounted a pertronix to a mallory before, it wasn't that hard, but you have to find the right one and have a bit of fab skills. |
johnhora |
Senior Member ![]() ![]() ![]() Group: Members Posts: 888 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None ![]() ![]() |
The Six already has a CDI, which is the same as an MSD except for the multiple-spark thing. Unfortunately, the points do wear mechanically--just not nearly as quickly as ones that carry lots of current. Even more unfortunately, most or all of the original Sixes used the Marelli distributor. There is no points-conversion available for that unit that I know of. Crane did make a prototype for it, but they concluded that there wasn't enough market and never produced them. Someone around here did get ahold of the prototype, and said that it worked well. But I don't know what the differences are from a more standard Crane unit. You might be able to talk someone into making bits to adapt a Pertronix II or Compufire or Crane optical gizmo into your distributor. If they do, they'll probably be able to sell a few of them. But it'll be pretty much custom work, so it won't be cheap. If you're willing to hand your distributor over to someone for a while, it might be worthwhile. Marelli points were NLA new for a good while; not sure if they are now or not. If they are still NLA, then the market for a points-replacement gets a bit bigger... --DD As Dave mentioned the 914-6 has a very good Bosch CDI unit. The points are used just as a switching signal for the CDI firing spark so they use very low voltage and thus don't wear out like Type 4 , 356 or Early 911 stock systems from arcing but just wear from the mechanical rubbing of the tab against the dizy shaft. There is really no reason for a stock 914-6 to go to another system. The MSD uses a multiple spark which is great for a high compression idling engine but they even go to just one spark after a certain rpm. And they are great for an engine that never had CDI. The Marelli parts are available again check here: http://www.sierramadrecollection.com/914-9...lectrical-c469/ If you don't like the Marelli there are Bosch 911 distributors that fit the application. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE I want to keep it looking original Then keep it original. That's a pretty good ignition system. |
johnhora |
Lo-Fi Version | Time is now: 3rd July 2025 - 05:30 PM |
