Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
If we have already upgraded to 911 adjusters on our rocker arms would this tool work on our 4 cylinders?
http://www.pelicanparts.com/techarticles/P...mpaign=20150402 Thanks David |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
It is doubtful that you will be able to fit the tool to the valves near the suspension ears.
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Probably work great with the engine out. I use a box end wrench and a dime.
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,653 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
I have this tool, used it on my 930 rebuild (engine out) I found that it seemed to work ok, a third hand would be best. If using feeler gauges it seemed spot on. When I measured with a dial gauge, all measured fat. I ended up setting with the dial gauge on each one. Nice having everything exact...
Harpo |
Stompki has a similar tool that uses a dial gauge but that is really expensive
David |
puffinator |
Member ![]() ![]() Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region ![]() |
infraredcalvin |
That's what I used...
Lo-Fi Version | Time is now: 13th July 2025 - 07:40 PM |
