Compression test |
Compression test |
last337 |
Apr 19 2015, 04:47 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
So I have the motor all cleaned up and Im at a crossroads whether I go ahead and break it down or not. I wasnt really planning on getting this deep into it but now I am wondering what to do since I never did a compression test before I took it out etc. A compression test turning it by hand doesnt really result in anything.
Mblizzard |
Apr 19 2015, 06:30 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
If the trans is still attached you can still do the test with the starter.
tomeric914 |
Apr 19 2015, 06:34 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
You could do a leakdown test with the engine out of the car. Somewhat easier in that you can lock the flywheel firmly in place with the engine out.
last337 |
Apr 19 2015, 08:04 PM
Unfortunately I didnt really know what I was doing when I took the engine out and pulled the flywheel off. I am planning to put it back on and learn that process of checking engine play. I think at this point I am about at point of just wanting to go through learning process of putting tin back on, fixing every other bolt that broke when removing the engine, fixing bad wiring, and putting it back in and just see where I end up. I know that may not be the best option but I know that whatever the result, I will definitely be much more comfortable dropping the engine when it comes time for a full rebuild. Any other advice?
Lo-Fi Version | Time is now: 1st June 2024 - 01:45 PM |
