Blast cabinet mod -- NPC |
Olympic 914 |
Apr 23 2015, 07:13 PM
Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Being a CSOB when I needed a blast cabinet I went to HF. I figured how bad can it be? Well it seemed to work ok at first, then I started having problems with the media tube floating up, pulsing and generally not working well.
I switch between Black Beauty coal slag and glass beads and had the problem with both I switched blast guns with another but no change. then after some research and seeing a different type of media tube that was a double barrel instead of a tube inside a tube. I bought one from TP tools. That solved my problem. I used the 12" tube they offer and made the standoffs to angle it into the little square at the bottom. this is with the table top model. I was just screening the glass beads and had the cabinet empty so I thought I would take some pics... Not much to see when its full of media. BTW you do need to put extra sealant on all the seams of these cabinets or it will leak like a sieve. Pics |
bigkensteele |
Apr 23 2015, 08:56 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I don't get why it has two tubes. I have the same problem with my cabinet (different design), but I am failing to understand how this works.
76-914 |
Apr 23 2015, 09:28 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Looks like that open end stands up above the sand so air has clear passage and sand is sucked in thru that hole drilled in the bottom of that other tube then to the gun? What is that hole size? I'm cheap and will make one. (IMG:style_emoticons/default/biggrin.gif) Thx for posting that.
brant |
Apr 23 2015, 10:22 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Link?
Ed_914 |
Apr 24 2015, 01:25 AM
Newbie Group: Members Posts: 20 Joined: 15-February 15 From: UK ,France and Holland Member No.: 18,433 Region Association: Europe |
I have a similar basting cabinet and had the same problem. The solution for mine was putting a second compressor on to it. The cabinet needs 15 CFM at 4 bar. When the airflow reduces it starts to pulse.
Btw this is my first post (IMG:style_emoticons/default/mueba.gif) |
Olympic 914 |
Apr 24 2015, 06:02 AM
Looks like that open end stands up above the sand so air has clear passage and sand is sucked in thru that hole drilled in the bottom of that other tube then to the gun? What is that hole size? I'm cheap and will make one. (IMG:style_emoticons/default/biggrin.gif) Thx for posting that. That's correct. This is what sent me looking for another media tube. pictures on the bottom of page 2.. with dimensions http://forums.thecmp.org/showthread.php?t=82231&page=2 I probably could have made one but I am trying to eliminate working on things that take away my time from working on the teener. Like, I just sold my boat because it needed to much maintenance. This is the link to the one I bought. they have just about every sandblasting accessory you could want. Looks like the price went up since I bought mine.. I used the 12" tube. but it depends on your cabinet... http://www.tptools.com/Skat-Blast-Pickup-T...8.html?b=d*8028 |
76-914 |
Apr 24 2015, 08:06 AM
Looks like that open end stands up above the sand so air has clear passage and sand is sucked in thru that hole drilled in the bottom of that other tube then to the gun? What is that hole size? I'm cheap and will make one. (IMG:style_emoticons/default/biggrin.gif) Thx for posting that. That's correct. This is what sent me looking for another media tube. pictures on the bottom of page 2.. with dimensions http://forums.thecmp.org/showthread.php?t=82231&page=2 I probably could have made one but I am trying to eliminate working on things that take away my time from working on the teener. Like, I just sold my boat because it needed to much maintenance. This is the link to the one I bought. they have just about every sandblasting accessory you could want. Looks like the price went up since I bought mine.. I used the 12" tube. but it depends on your cabinet... http://www.tptools.com/Skat-Blast-Pickup-T...8.html?b=d*8028 What is the size of the opening that the sand is sucked into? 3/8"? |
luskesq |
Apr 24 2015, 09:38 AM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Thanks for the tip, I'll try it. I have the same cabinet, did what you did with new gun that requires less CFM & new pickup from TP and also experienced the tube movement.
Keith |
madmax914 |
Apr 24 2015, 10:20 AM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
I have the same cabinet, I just ordered the new pick-up tube from TP Tools. Thanks for the tip!
Lo-Fi Version | Time is now: 9th June 2024 - 03:39 PM |
