Speedo angle drive, I have searched - believe me |
sdoolin |
May 6 2015, 01:47 PM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
So my speedo quit working a couple of days ago. I have verified that it is not the head unit or the cable itself. Running the tranny end of the cable with an electric drill causes the needle to move.
Looks like it is the "angle drive" unit (to me) that has failed. I have removed this from the tranny and cleaned it up. Spinning the female end of it (that bolts into the nose piece) with a screwdriver only _sometimes_ causes the male end (output to the cable) to turn. It seems very "loose". I have seen several threads on this (larmo63 has a recent thread) but I cannot tell if the piece is rebuildable and if so, how to do so? Looks like Pelican has replacements but they are $95 and I am too busy spending money on my 911 to go and buy the part from Pelican. I did search and found great info on how to remove tach to get to speedo to remove speedo cable and trip reset cable, just can't quite find an answer to this specific question. All help appreciated... |
Millerwelds |
May 6 2015, 01:59 PM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
I bought a used one from BDStone on here. swapped it out and it works fine now. I think I paid $50. Post a WTB and I am sure others will pipe in. (IMG:style_emoticons/default/beerchug.gif)
SirAndy |
May 6 2015, 02:06 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
McMark sells a upgraded version that has two o-rings, send him a PM ...
(IMG:style_emoticons/default/smile.gif) |
Java2570 |
May 6 2015, 02:11 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
914 Rubber is now selling the ones McMark came up with! I got in on a GB for that one....
sdoolin |
May 6 2015, 02:43 PM
Bob L. |
May 6 2015, 02:55 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Yeah, that's the "Speedo angle drive". Bdstone should be able to help you out.
Send him a P.M. |
sdoolin |
May 6 2015, 03:04 PM
PM does not find a user named "bdstone"?
Larmo63 |
May 6 2015, 03:39 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I never did get mine fixed. I didn't understand what I should do to fix mine. I never got it the part out of the transmission.
I just guess my speed. |
stugray |
May 6 2015, 04:45 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
PM does not find a user named "bdstone"? http://www.914world.com/bbs2/index.php?showuser=1319 'bdstone914' |
bdstone914 |
May 6 2015, 05:17 PM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Yes i have them. Yes,you should only need the angle drive. The improved upper parts is to fix leaks. Won't make your speedo work
sdoolin |
May 6 2015, 05:56 PM
PM sent bdstone914.
This place is great... |
Mikey914 |
May 6 2015, 10:58 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the upper is nice to stop leaks. After you get one from Bruce you can sacrifice the old one to see. I have one on my car that someone had removed the end cap and epoxied back together. So, I do believe it can be done. What it takes and how to are still a mystery.
Lo-Fi Version | Time is now: 23rd May 2024 - 03:45 AM |
