Fuchs Offset... |
Fuchs Offset... |
MikeM |
May 13 2015, 07:50 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hello...does anyone know the offset of the 4 spoke 914 Fuchs ?
Thanks. |
mskala |
May 13 2015, 08:21 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
MikeM |
May 13 2015, 08:30 PM
ok thanks!!!
MikeM |
May 14 2015, 07:46 AM
Now I'm confused. I'm looking at some replicas but the ad says "4 inch backspacing".
What does ET40 mean? 40 mm.? Mike |
rhodyguy |
May 14 2015, 07:56 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The back spacing, measured with a tape and rule, is 4 5/8" on OEM Fuchs wheels. The 5/8 makes all the dif in the world on a narrow body car, with unaltered wheel wells, and running 195 width tires.
Mueller |
May 14 2015, 07:58 AM
Now I'm confused. I'm looking at some replicas but the ad says "4 inch backspacing". What does ET40 mean? 40 mm.? Mike http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101 Offest is an European term, backspacing is redneck (I mean American term) (IMG:style_emoticons/default/smile.gif) Backspacing is from the hub surface to the out most point of the rim. You measure this by using a straightedge across the wheel and measure... a picture will explain better than me.. |
Mueller |
May 14 2015, 08:01 AM
If you notice, backspacing takes into account the thickness of the lip, offset does not.
So 2 rims with the same width and offset may have different backspacing depending on how the rims have been made. I wouldn't think it would vary by more than 1/4" to 3/8" max |
MikeM |
May 14 2015, 08:08 AM
OK great info!! So I guess now I need to ask what is the "backspacing" measurement on a 4 paddle Fuchs wheel?
Thanks |
MikeM |
May 14 2015, 08:10 AM
OK...I just re-read Rhodyguy's response. So a 4 inch backspace will not work? Correct? It's a narrow body car.
Mike |
Mueller |
May 14 2015, 08:20 AM
OK...I just re-read Rhodyguy's response. So a 4 inch backspace will not work? Correct? It's a narrow body car. Mike I guess you could see what you currently have and compare the numbers? The rims you listed with a 4" backspace will be closer to the fender edges and might rub in the back. |
rhodyguy |
May 14 2015, 08:28 AM
4"? Results may vary. IMHO, a major factor is what size tire you intend to run. You don't want to drop $$ on a wheel and tire package only to find you need to make adjustments to the chassis. Those adjustments, rolling the wheel wells or trimming the lips, will be expensive to undo.
MikeM |
May 14 2015, 08:38 AM
Good point. I have almost new 195/55's now so that's what I would be using.
Don't really want to roll the quarter panels. |
rhodyguy |
May 14 2015, 08:46 AM
What style of wheels are currently on your car?
MikeM |
May 14 2015, 08:50 AM
Mahles...should have mentioned that!!
stugray |
May 14 2015, 09:52 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I run 205 50/15 Hoosiers on the stock 2.0L Fuchs and they rubbed in the rear, on the inside, on the track (probably would NOT rub on the street).
That is with NO shims for camber (max camber). So I used 3/8" spacers and still have room on the fender side. 195s should fit with the stock rims and no spacers. Note: LONGER bolts/studs are required (even longer than the special 2.0L-Fuchs bolts) with the spacers. |
Lo-Fi Version | Time is now: 29th May 2024 - 01:49 AM |
