Adding gauges, Where did you put them? |
jeffdon |
May 14 2015, 01:32 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
I have added a CHT and OP gauge to my car (the 2" or so diameter ones). Since resurrecting the car, I have just had them wedged into the old DIN radio slot. It works, but its fugly. My car never had a console, and I never put the cubby box back in. I kinda like it all open.
I am looking for ideas as to where to do a permanent mount for them. Since I am not running a radio, I suppose I could put a new piece in the radio location that is cut for the gauges. I am not a fan of the metal under dash mounts, and the A-pillar mounts are a bit boy racer to my tastes. I have seen the ashtray mount trick, and am not wild about it either. Anyone got any other creative ideas for where I could locate a couple gauges? Oh, and I MIGHT ad and Oil temp gauge while at it. |
JmuRiz |
May 14 2015, 01:44 PM
914 Guru Group: Members Posts: 5,432 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
In the gauge panel is the best:
Either add a quad-gauge or add a triple gauge and get a tech with a fuel gauge inset (like a turbo boost gauge) Granted, these cost $$, but they look GREAT! |
jfort |
May 14 2015, 02:37 PM
Senior Member Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
there is a 2 gauge holder that replaces the ash tray
campbellcj |
May 14 2015, 03:00 PM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I had some in the radio location for a few years and thought it looked fine, but now prefer the triple/quad gauge for at-speed visibility reasons.
type47 |
May 14 2015, 03:39 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
914forme |
May 14 2015, 04:57 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
You can also redo the stock location, and add a bunch of gauges over there. I did it on my auto-x car. But then I also ran a bike speedo, to keep cops off my behind, and a Monster Tach. But full compliment of gauges 2 CHTs, oil temp, pressure, voltage, a fuel gauge was dumped where the radio used to be. Revamp of this car will be Full Size Speedo, Large VDO tach, and a quad gauge, but it is going to be on the street / Auto-x / DE car and Subaru powered so, oil pressure, fuel, water temp, and voltage. Oh and full stereo so I lost that spot. You can see the quad gauge ideas below |
02loftsmoor |
May 17 2015, 04:14 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
Spoke |
May 17 2015, 06:31 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
This is my previous '74 914 with lots of gauges. 2 gauges on the steering column and 2 in the ashtray.
I think all the gauge holders can be bought at your FLAPS. Attached image(s) |
r_towle |
May 17 2015, 08:30 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Getty dashboard like Sir
Andy has |
michael7810 |
May 17 2015, 10:17 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
toolguy |
May 18 2015, 10:44 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
bigger is not necessarily better. .
Attached image(s) |
SirAndy |
May 18 2015, 10:52 AM
Resident German Group: Admin Posts: 41,661 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Getty dashboard like Sir Andy has Plenty of space one could use for additional gauges on a /4 since you don't need all them fancy things that clutter up my dash. (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1181552489.jpg) |
VaccaRabite |
May 18 2015, 04:03 PM
En Garde! Group: Admin Posts: 13,450 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm3.staticflickr.com-1435-1431986583.1.jpg)
a-pillar pod is really easy to put on, and works well. Zach |
Highland |
May 18 2015, 06:42 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Elliot Cannon |
May 18 2015, 07:44 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I made a small console below the middle of the dash. I cut 2" black plastic pipe at an angle for bezels to better see the gauges from the drivers seat. The switches are for the fuel pump shut off, driving lights and interior light. All the gauges are lighted hence a real rats nest of wires inside the console. (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
DBCooper |
May 18 2015, 08:46 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
I like the quad gauge idea because it puts everything in one place. This is with a VDO tach with programable red line and shift light, plus an electronic speedometer. It's not original, but it's still in the VDO style, is modern tech, and it works with different engines/transmissions.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1432003591.1.jpg) |
GaroldShaffer |
May 18 2015, 08:58 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm3.staticflickr.com-1435-1431986583.1.jpg) a-pillar pod is really easy to put on, and works well. Zach (IMG:style_emoticons/default/agree.gif) Attached image(s) |
dangerranger01 |
May 19 2015, 11:00 PM
Member Group: Members Posts: 145 Joined: 12-August 05 From: Boring, Oregon U.S.A. Member No.: 4,578 Region Association: None |
GeorgeRud |
May 20 2015, 01:11 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Dion |
May 21 2015, 06:54 AM
RN Group: Members Posts: 2,766 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Some variation. Dual holder next to each other.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 28th May 2024 - 06:55 PM |
